Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > CNC Teknix Servo Control Products > TEKdrive Servodrives
TEKdrive Servodrives Discuss TEKdrive Servodrives here.
Old 06-22-2009, 12:41 PM
bartL is on a distinguished road
TEK10 red LED keeps flashing
Hello,
I'm busy retrofitting my Hardinge HXL lathe with servomotors and TEK10 drivers. The system is running on 80Vdc and 10A max. A few weeks ago I already had this system running and did some testing with it. After that I removed the complete system to change the setup and complete the wiring.
Now this week I've tried to assemble the elektronics on the machine again
but without any results. As soon as I power up the system the red LED starts flashing. I've checked everything and it all seems to be ok. I got the 5V enable signal, the 12V on upper and lowerboard and the 80Vdc motor power input. Does anyone overhere has a suggestion what this problem can be?
Regards,
Bart
Old 10-17-2009, 04:34 PM
Dirkos is on a distinguished road
Hello,
The same happened to me, do you find out wat the problem was / is?
regards,
Dirk
Old 10-19-2009, 04:10 PM
Dirk,
I couldn't find the problem myself so I contacted CNCTeknix and they asked me to send the driver back for a check. There was a problem somewhere in the circuit and they fixed it without any costs! Good service!
Bart
Tek10 Servo Drives On Special Kookaburra Product Announcements & Manufacturer News 4 09-27-2010 12:36 AM
Need Help!- Mycenter 1 Alarm Flashing Pmp Audio Fanuc 8 02-23-2009 10:12 PM
TEK10 problem! Patrick_v_M Servo Motors and Drives 0 04-17-2008 10:22 PM
Need Help!- Flashing bit mr_electrician Fanuc 3 02-15-2008 02:19 PM
Teknix Tek10 VS Gecko G320 gripen General Topics 1 06-06-2007 12:01 AM
