Results 1 to 8 of 8
Thread: LC 4896 Accuracy Problem
    Jan 2009
    was wondering if any one can help. when cutting dadoes in plywood, program Has router cut each dado half way in length then cut from other side to meet in the middle. Problem is where they meet in the middle is off.( see exagerated blue line in picture). Any idea of what prob could be..Thanks Ian
    Attached Thumbnails Attached Thumbnails LC 4896 Accuracy Problem-vent_test.jpg
    Oct 2007
    because it is so perfectly duplicated i would ask how and in what program the file was written?
    a small jog in the vectors - say if you made one and then used array to duplicate would do this.
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Jan 2009
    Jim, it was created in v-carve pro. I created a 3/8 by 12 inch vector and then copied it with 3/8 space between. It was cut with a 3/8 2 flute mortise bit at 400 ipm and .210 deep. I'm also having a similar problem in Planit solid when cutting dadoes and thru cutting panels. I'm wondering if it could be problem with machine. Thanks Ian
    Jan 2009
    Jim, Thanks for spending the time with me, and resolving this issue. Thanks Ian
    Mar 2003
    Shelby Twp, MI....USA
    What was the resolution?
    Oct 2007
    he had created a rectangle the width of his bit and when you run a profile inside then it starts the toolpath from both ends and meets in the center.
    i showed him how to create a single vector, array then run toolpath on center
    jim
    Mar 2003
    But that doesn't actually fix the original issue, it just avoids it.
    My guess would be machine or tool deflection. By not starting in the center, you don't see it.
    Oct 2007
    i was surprised this is how it toolpathed, here is the original and the fix
    jim
    Attached Thumbnails Attached Thumbnails LC 4896 Accuracy Problem-fullscreen_capture_1162010_91252_.jpg   LC 4896 Accuracy Problem-fullscreen_capture_1162010_93544_.jpg
    1. Techno LC 4896
      By mechcanoer in forum Techno CNC
      Last Post: 05-18-2012, 04:43 PM
    2. LC 4896 starts automagicaly
      By Pplug in forum Techno CNC
      Last Post: 04-28-2010, 02:06 PM
    3. Problem with VF2 accuracy
      By X7racer in forum Haas Mills
      Last Post: 07-09-2008, 02:48 PM
    4. Accuracy problem
      By BackyardWorkshop in forum DIY CNC Router Table Machines
      Last Post: 05-31-2008, 04:29 PM
    5. fanuc 18m accuracy problem
      By _pk_rasta_ in forum Fanuc
      Last Post: 04-11-2008, 02:03 PM
