I just recently re-greased using this & a grease gun, works great, no problems yet
http://www.slick50.com/products/OtherProducts.htm
I have a techno lc4896 and have the grease/oil sheet but wonder if there is any substitutions that can be made. For example the sheet recommends Renolin CLP 100 and I have a bottle of gear oil SAE 75W-90. Are these at all compatible? I have multi-purpose lithium grease that I use for the y-axis ballscrew. Would be nice to have a clearer document for what can be used. Also, it would be great to see some videos of lube maintenance.
Applying lubricant to the rails inside of the Gantry with an "acid brush" doesn't seem like the most effective solution. Is there a spray lubricant that is suitable for this job? It's hard to know if the rails inside receive enough lube!
Grant
