Does anybody have a trick to adjust the z height of the tool mid program? The only way I can get it to work is to reset the file, which doesnt work very well wth a toolchange file. |
| This is truly an awesome tip! Was it in the manual anywhere?
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| I read it but that doesn't mean I understood it! Thanks!
While running a Techno machine an offset can be created on any axis. Pause the machine, Double click on the axis you want to change ( x,Y,Z, etc) Type in a positive number to offset the cutter to cut higher, and a negative number to cut deeper. IE: I would type in -.1 to add that much depth to the cut. Be carefull because the axis will do what you tell it to. I forgot the point symbol once, and it indeed added 1 inch to the depth of the cut. It was dramatic!!! |
| SCM Xilog adjust toolchange height | derek_Hampton | CNC Machining Centers | 1 | 12-14-2009 09:50 AM |
| Mach 3 manual height adjust | The_Fixer | CNC Plasma and Waterjet Machines | 2 | 06-14-2009 02:15 PM |
| Need Help!- How do I adjust the tool changer height parameter on a TNC145 (Interact 412) | Skin | Bridgeport and Hardinge Mills | 3 | 05-27-2009 08:16 PM |
| New Raised-Gantry CNC Router from Techno is Perfect Height for Foam Applications | carolpratt | Product Announcements & Manufacturer News | 0 | 12-05-2006 03:04 PM |
| Tool Height Touch Sensor for Techno-Isel | mikkojay | DIY-CNC Router Table Machines | 8 | 08-08-2006 03:28 PM |
