a standard fanuc post should work you just need to sort out what is causing your machine problems, comments are a frequent area for problems, put any suspect code in ( ) then once you figure out go into your post and see if you can figure out how to adjust it to leave out the problem ares. also another area is arcs, make sure your arc settings are correct.
if you post a small g-code file as it is and won't run, more will be able to advise
LinkBack URL
About LinkBacks
