I posted this on another thread but wanted to share with the Techno Family, since it is likely that some of you have experience with the HSD ATC Spindles.
I recently bought a "New" HSD ATC ES915 from an out of state vendor. We communicated frequently and in detail leading up to the sale.
I sent the money for the spindle, cables, three ISO 30 ER32 tool holders and a VFD. When the spindle arrived:
1. I discovered that the top of the fan housing had a broken rib and a piece of the plastic was inside the spindle.
2. Three (3) of the fan blades had nicks that lined up perfectly with the broken rib on top of the fan housing.
3. The socket head screws holding the fan housing on, were showing signs of what appeared to be rust.
4. There were a significant quantity of aluminum shavings on the external cooling ribs of the fan housing.
5. There were numerous scratches all over the housing.
6. The inspection sticker had been removed, leaving a lot of scratches, and another sticker placed in the same location.
7. The black oxide finish was 90% gone from the steel bearing housing on the nose of the spindle, with obvious signs of wear and nicks.
8. There were two (2) locations showing dates... 2006!
9. The manufacturer states that there are three (3) pieces of documentation accompanying every spindle, including a Manufacturers Certificate of Inspection and a manual for installing, operating and maintaining the spindle... all three were missing.
10. The tool holders were missing.
11. ... and more....
I contacted the vendor about the damage and why the spindle had all the markings of a used or refurbished spindle. I also asked about the 2006 dates and all the issues above.
1. I was assured it was a "New" spindle and that all the wear was from "setting up" and "testing" the spindle and VFD.
2. I was told that the manufacturer was no longer sending the aforementioned documentation.
3. I was told that the fan was broken in transit, even though the box had no damage in the area where that end of the spindle was located.
4. I could not get an answer about a 4+ year old "New" spindle.
5. I was told that the tool holders were back ordered (and they did finally arrive). They were SK 30 Taper, not the ISO, and I could not get any response regarding the discrepancy nor questions regarding the pull studs.
I sent pictures to the vendor and was told to ship the spindle back and it would be replaced. Since I could not get answers to all of the questions I asked about the points above, I sent an e-mail canceling the transaction.
I requested a UPS Call Slip for the VFD, Cables and tool holders, as well as a full refund check.
The spindle is in transit and I am waiting on their response. They are still trying to seek an unjustified damage claim from UPS.
Questions:
Does this sound like a new spindle to you?
Does black oxide wear off during "test" runs?
Does HSD (or any manufacturer) typically supply their vendors with 4+ year old "New" spindles?
Any insights would be appreciated.
Dave
LinkBack URL
About LinkBacks
