I reinstalled XP Pro.
I reinstalled the Techno CNC Interface.
I set the parameters (M Scales, etc)
I opened a file and it did not go friggin nuts...
When I try to run the program, the Z Axis goes all the way up and faults out. I set the X and Y axis to zero prior to running the program.
I thought I might need to touch off the tool after zeroing out the X and Y axis, but it required me to do the touchpad test first. So I went to SYSTEM>ADVANCED>TOUCHPAD and tried to test the touchpad, I immediately get Touchpad test failed (0). It doesn't even let me do the test.
I have checked the connections on the controller MOBO and all is well. Not sure where to go with this now... I will not be able to run any programs if I cannot touch off the tools.
Also, the HOME limits are still an issue, as they fault out every time.
D
LinkBack URL
About LinkBacks
