Results 1 to 5 of 5
Thread: start stop switch wiring
    May 2009
    any body know the pinouts for the start stop switch? I'm thinking of switching my machines to xp, unless things have changed you have to have a start stop switch to interrupt the run in xp.
    Registered Pplug's Avatar
    Jan 2007
    It depends on what type of controller and card you have.
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
    May 2009
    Pplug, you are absolutely right I use the pci 400 cards with the riser card on my 4 axis and w/o on my three axis,
    Jan 2007
    if you had the regular LC control box I could help you. Although heres where I found out what pins are for the probe on the aux connector in my controller.... First I loaded the free probing software. Next, I went to the diagnostic section in the probe settings panel. I then proceeded to see where the probe was supposed to be connected by shorting ground to the pins. I think an e-stop can be wired in this way.
    Apr 2010
    England
    Commandline switch to start and stop server:
    cerberus.exe /start starts ftp server
    cerberus.exe /stop stops ftp server
    Regards
    JMG
    1. need advice on start stop switch replacement on jet jmd-18pf
      By Jet user in forum Benchtop Machines
      Last Post: 02-20-2010, 03:47 PM
    2. Where to get relay and e-stop switch
      By forrest39 in forum Benchtop Machines
      Last Post: 10-14-2009, 11:39 AM
    3. Need Help!- E-Stop Switch
      By crocky in forum Automation Technology Products
      Last Post: 10-10-2008, 11:34 AM
    4. Emergency Stop Switch
      By BOBINETTE in forum Hobbycnc (Products)
      Last Post: 12-28-2007, 12:41 AM
    5. pminmo BOB and NC E-Stop switch
      By kiltjim in forum General Electronics Discussion
      Last Post: 11-20-2007, 07:57 PM
