Results 1 to 5 of 5
Thread: Z plunging beyond origin
    Nov 2004
    uk
    When a file is started from the origin, after 100% complete it then returns to origin, but very occasionaly it goes beyond z=0 and stabs the part. Kind of annoying after a 1hr delicate part has just finished.
    The gcode doesn't show this plunge, my z axis brake clicks away and seems to work fine.
    Any body know whats happening here?
    May 2009
    check your setup file and make sure it isn't set to return to 0 after run. you should be able to set it so it can be sent where ever you want
    Oct 2010
    Did you ever figure out what caused this problem? It just happened to me after running a part with 2 tools. Drilled holes first with short bit, routed part with longer bit. Then after the program finshed the router went to the my zero in x and y then drop into the part and just stayed there as the router spun.
    Nov 2004
    uk
    I didnt find out why it plunges too deep no.
    I just did as montabelli said, changed the setup not to return to origin, havn't had a problem since.
    May 2009
    Quote Originally Posted by eruzich View Post
    look at setup make sure it doesn't return to the original settings (offsets) after run. also I try and make sure the 0-0-0 is never over a part. that way, since Murphy is an optimist such mysteries as poltergeists are accounted for too, to some extent.
    1. Need Help!- mach 3 z-axis plunging
      By bjcnc in forum Mach Mill
      Last Post: 11-19-2009, 07:30 AM
    2. Z axis randomly plunging
      By Don-in-Japan in forum Benchtop Machines
      Last Post: 05-31-2009, 02:58 PM
    3. Newbie- Z Axis stalling when plunging slot drill
      By Adethelathe in forum General Metalwork Discussion
      Last Post: 05-26-2009, 11:27 PM
    4. Need Help!- Plunging chatter and other Z-axis issues
      By cnczoner in forum Benchtop Machines
      Last Post: 02-03-2009, 09:42 AM
    5. Need Help!- What causes plunging?
      By Sinkoumn in forum WoodWorking
      Last Post: 08-25-2008, 03:55 PM
