Results 1 to 3 of 3
Thread: Reversing direction control
    Feb 2010
    Question Reversing direction control
    I am setting up an old CNC table to run with Techno controller and motors. I am installing limit switches now.
    I have noticed however that the directions are all the opposite of what they should be. The motors plug onto the control board with two sizes of tabs to prevent them from being switched there. Is there a way to flip the controls in the software? I have not had a chance to look into it much, thought I would check on here first.
    Thanks in advance for the help!
    Registered Pplug's Avatar
    Jan 2007
    Sounds like you will have to switch the wires. You might be able to put in negative values into the screw pitch section but I could be wrong.
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
    May 2009
    if your motors are servos and when you push the jog arrow and they move as expected but in the opposite direction you can switch this by the addition of a minus sign in front of the step count in the setup section of the software. if the x y axis are reversed, there is a tab to flip that as well.
    if you have servos and you just reverse the polarity of the motor it will lurch and give you an excessive position error.
  1. Stepper Motor Spontaneously Reversing Direction
    By JasperBurtonIII in forum Linear and Rotary Motion
    Last Post: 11-25-2009, 12:06 AM
  2. Keling 425oz/in randomly reversing direction??
    By mulligan in forum Stepper Motors and Drives
    Last Post: 05-17-2009, 06:15 PM
  3. reversing homing direction without inverting axis?
    By draughted in forum LinuxCNC (formerly EMC2)
    Last Post: 04-08-2009, 05:04 AM
  4. G320 - reversing default motor direction
    By radioactive in forum Gecko Drives
    Last Post: 04-07-2009, 04:20 PM
  5. Need Help!- reversing display direction
    By barnesy in forum Mach Mill
    Last Post: 12-17-2008, 10:47 PM
