TechnoCNC Patriot and Inventor Pro 2016 HSM
Results 1 to 6 of 6
Thread: TechnoCNC Patriot and Inventor Pro 2016 HSM
    Oct 2010
    Default TechnoCNC Patriot and Inventor Pro 2016 HSM
    Up to this point, we've used MasterCAM to generate g-code for our TechnoCNC Patriot Milling Machine.
    We also use Inventor Pro 201X to do our CAD. Now that Autodesk has released the CAM plug-in HSM for IP201X, we'd like to use that
    to do our tool paths. We've had mixed success. I believe the problem involves picking the right post-processing plug-in.
    Does anyone else use this approach..and if so...what post-processor do you pick from the HSM drop down?
    Member ericscottf's Avatar
    Sep 2012
    Default Re: TechnoCNC Patriot and Inventor Pro 2016 HSM
    Doc,
    We've been working with the folks at Autodesk on this, and hope to have a good solution soon.
    For now, if you pick the generic FANUC post, all you have to do is remove the comments/other stuff at the beginning of the file and you should be good to go. You can remove those lines in a text editor like notepad, or the one built into the CNC interface.
    Regards,
    Eric
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
    Oct 2010
    I did run into one snag. It appears that either the TechnoCNC post processor or the TechnoCNC software does not work and play well with the ramp commands.
    Sep 2012
    Send us the gcode file that is getting put out and I'll check it out. Our address is on our website, Armor CNC Systems under contact.
    Eric
    Jan 2017
    Will the same post processor work for a TechnoCNC LC series 3024? I am new to this and find MasterCam very difficult. I do pretty well with Inventor so I was hoping to use it to mill my parts rather than MasterCam
    Sep 2012
    Quote Originally Posted by toaren01 View Post
    Yup, same post.
    Eric
