- Over travel limit Z question on a HD
Everything has been running ok....Changed some tooling and re zeroed the z at the spoil board .... Now when I start the program I get an error NC 118 Negative software overtravel limit Z message and it doesn't move .....Any one have any idea where to start looking for the problem
Thanks, Paul
Re: Over travel limit Z question on a HD
I don't know any thing about your controller, but I would check to see if there is a reset limits , or reset soft limits switch in the controller files somewhere
- You may not post replies
- You may not edit your posts
Forum Rules
