Hi good day, what kind or name of oil and grease ur use for, and u are using gcode progam ?
A lot more work involved here. As I suspected, the x and y axis assemblies are identical
with the exception of how the y-axis attaches to the gantry columns. To clean this
I decided to disassemble the whole thing. Why not, I was already there.
Attachment 225128
Attachment 225130
Attachment 225132
Attachment 225134
Attachment 225136
Pulled the bolts, removed the column and cleaned it.
Attachment 225138
Attachment 225140
Had to remove the motor to get at all the bolts.
The connector is for the limit switch.
The green board terminates the connections to the motor.
Attachment 225142
Attachment 225144
Attachment 225146
Removed the covers. I doubt it's ever been cleaned.
Attachment 225148
Attachment 225150
Removed the assembly from the gantry column.
Attachment 225152
Cleaned up nice.
Attachment 225154
Greased the ballscrew and oiled the guides.
Attachment 225156
Ready to be re-assembled.
~john
