| Teachers Hang out Discuss and share your ideas here. |
| change inch welding measures to metric We have a problem and we need fast answer. If i have a inch dimension picture where is weldin symbol 1/2 at one side of the part what it mean when i convert it for metric system ? |
| Not seeing the drawing, I cannot say for sure. It could mean: ˝ (inches) = 12.7 mm wide weld bead Sometimes 1 / 2 means “one of two” |
| One of two would mean a skip weld with 1" (25mm) weld every 2" (50mm). See here: http://www.welding.com/weld_symbols_..._symbols.shtml
__________________ -Eric |
| Picture added I make a raw picture what i mean. |
| In this case the symbol is for a 1/2" fillet weld which would be 12.7mm. To convert these fractional inches to metric, divide the numerator by the denominator and multiply by 25.4. For instance the 3/8" fillet weld shown would be 3 divided by 8 equals .375 times 25.4 equals 9.525mm. |
| Looking at your drawing, 1/2 symbols mean weld both sides of the joint using 1/2 inch (13mm) wide weld bead. Both sides because 1/2 is on both sides of the weld specification line. The 3/8 symbols mean weld one side using 3/8 inch (10.0mm) wide weld bead. Put the welds on the joints the symbols point to. |
| This is clear now. Thank you all. |
| Need Help!- change inch welding measures to metric | juha | Welding, Brazing, Soldering, Sealing | 3 | 06-17-2008 09:48 AM |
| Metric to inch conversion | BobF | Mach Software (ArtSoft software) | 3 | 12-28-2007 11:53 AM |
| DRO - Metric or Inch | DJ Morrow | General Electronics Discussion | 2 | 11-15-2004 03:06 PM |
| Metric vs Inch - arguements pro & con | DJ Morrow | Mini Lathe | 10 | 08-12-2004 09:46 AM |
