Go Back   CNCzone.com-The Largest Machinist Community on the net! > Teachers forum > Teachers Hang out
Teachers Hang out Discuss and share your ideas here.
Old 04-12-2007, 05:17 PM
Muzzy is on a distinguished road
tool life spread sheet for operator
Any advice on how to manage/monitor and evaluate tool life effectively for a milling operation? We are milling the same part from the same material (cast iron) in the same heat treated condition with similar hardness . The cutting conditions remain the same with the exception of the width of cut. are mill are no older then 5 year old and some are new in 2007. I hope this is a better question. I'm looking to have some thing the operator can do a check off as they change tools.
Old 04-13-2007, 01:09 AM
davereagan is on a distinguished road
Is the tool coated? Are you running dry or flooded? I would make a chart noting surface speed, chipload and depth of cut/ number of passes. Evaluate the edges of worn tools and note it on the spreadsheet. Increasing chipload and depth of cut can increase tool life becuase you are taking less swipes to get it done. That is maximized when you start chipping the insert of cutting edges. If you wrote me with the operation you were doing, I could be more specific. What hardness is this cast iron?
Dave
Tool Life Management marko440 Fanuc 8 04-07-2010 04:47 PM
tool life any info available rapid Fanuc 4 12-08-2009 02:24 PM
Tool Life Management Jake E. General CNC (Mill and Lathe) Control Software (NC) 6 11-05-2009 02:13 PM
Tool life Muzzy CNC Tooling 0 04-11-2007 05:47 PM
Carbide tool life? ozzie34231 General Metalwork Discussion 11 11-01-2005 08:33 AM
