Results 1 to 2 of 2
Thread: Asking about process from G-code into stepper pulse???
    Jan 2010
    indonesia
    Smile Asking about process from G-code into stepper pulse???
    I'm trying to establish some techie info wrt the final leg of the CNC process/chain ....
    after CAD, G-Code gets generated, this G-Code in turn is fed into a CNC app (like Mach3), which carries out some maths to turn cordinate info into the pulse trains required to drive the stepper motors?
    -> Has anyone a good linky or two which explains this CNC app stepper driver board in more detail?
    -> And How process from g-code turn into some moving /fed ??
    I'm toying with the idea of learning how to do a CNC pickup winder GUI / Program
    (I've already built a CNC winder & use my own G-Code in conjunction with Mach 3 to drive it)..
    it might be a handy goal to learn more & also a bit of fun.
    Registered neilw20's Avatar
    Jun 2007
    Heres how mach3 does it.
    See attached.
    Attached Thumbnails Attached Thumbnails Asking about process from G-code into stepper pulse???-mach3mysteries.pdf
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  1. Need Help!- Stepper Motor Pulse Input Problem
    By scratali in forum Stepper Motors and Drives
    Last Post: 05-20-2012, 04:07 PM
  2. Asking G-code into stepper pulse???
    By geethat in forum Controller & Computer Solutions
    Last Post: 09-03-2010, 12:20 PM
  3. Pro/E Pro Engineer Process to G-code
    By saris in forum PTC Pro/Manufacture
    Last Post: 11-08-2008, 10:34 AM
  4. g code problems and post process
    By woffler in forum Dolphin CADCAM
    Last Post: 02-09-2008, 09:20 PM
  5. Right pulse for stepper
    By cncbox in forum Stepper Motors and Drives
    Last Post: 08-16-2005, 01:18 AM
