Results 1 to 2 of 2
Thread: 4" Rotary table with stepper motor ( 57 x 76mm, 3.0A )
    Mar 2010
    China
    4" Rotary table with stepper motor ( 57 x 76mm, 3.0A ) x 1 set
    sells well in the world cnc market,high qulity and low price.
    warmly welcome for all your inquires!
    Specifications of Rotary table for 4":
    1. Diameter: 100mm
    2. Morse taper of the center hole: 2#
    3. Diameter of the center hole: 20mm x 8
    4. Height of center for Verti.mounting: 70mm
    5. Width of T-slot: 6mm
    6. Adjacent angle of T-slot: 90 degrees
    7. Width of the locating key: 10mm
    8. Modules of worm and worm gear: 1
    9. Transmission ratio of the worm gear: 1:72
    10. Graducation of the table: 360 degress
    11. Readout of the handwheel: 2
    12. Minimum value of vernier: 10"
    13. Indexing accuracy: 120"
    14. Max. bearing (with table Hor.): 20 KG
    15. Max. bearing (with table Vert.): 10KG
    16. Speed of table: 5 rpm
    17. Blacklash for the table: 6 degrees
    18. N.W. : 8KG
    19. G.W. : 9KG
    20. Case dimensions: 245 x 165 x 112mm
    to konw more pls brows Hppp://www.atron.com.tw
    Ray
    Msn:ray@diylife.com.tw
    skype:twhoumau014
    Taiwan Hou-mau Machinery co,ltd.
    Attached Thumbnails Attached Thumbnails 4" Rotary table with stepper motor ( 57 x 76mm, 3.0A )-4_rotary_table.jpg
    Jan 2010
    How much for the QTC-97 kit?
    How much to deliver to USA zip 27105
  1. Just IN- 8" Rotary table with stepper motor ( 86 X 78mm, 4.0A ) x 1 set
    By sindychen in forum Product and Manufacturer Announcements
    Last Post: 11-12-2010, 01:06 AM
  2. Need Help!- What size stepper to drive a 10" rotary table?
    By fido in forum Stepper Motors and Drives
    Last Post: 11-12-2008, 06:57 AM
  3. Stepper Motor for 4" Rotary Table
    By cliveastro in forum Benchtop Machines
    Last Post: 06-25-2008, 01:53 PM
  4. Newbie- Stepper motor and rotary table
    By ksor in forum Stepper Motors and Drives
    Last Post: 03-13-2008, 07:59 AM
  5. "Lathing" with a rotary table?
    By JMcDonald in forum Benchtop Machines
    Last Post: 10-13-2007, 05:47 AM
