Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 04-17-2005, 05:45 PM
gizmo is on a distinguished road
Taig mini mills
Can anyone suggest a complete set up for me using a Taig mill and servo motors.
I would like to build the machine myself with the help of a friend for the electronics side of things. I will be cutting mostly copper electrodes and some ss 420. Speed is not too important but accuracy is, within .001".
If you have built a complete set up yourself I would appriciate your advise and experience.
Old 04-17-2005, 10:24 PM
Moderator
Halfnutz is on a distinguished road
You can bolt the three axis servo kit from IMService (cadcamcadcam.com) right up to the taig cnc ready mill and go. If you want to build a slightly better system buy the Taig CNC ready machine, three gecko servo drives and get the toroidal transformer, capacitor and bridge rectifier and globe nema 23 ready motors from IMService. Build a box and wire it up. All the info you need for the wiring is right here at CNCZone in the electronics section and with the gecko drivers.
Halfnutz
Old 04-19-2005, 10:52 AM
re globe servos
If I use the globe servos (404058) from imservice what Gecko drives would you recommend, 320 or 340?
Are servos the best option?
Old 06-06-2005, 03:22 PM
deep_drill is on a distinguished road
Taig CNC Ready Mill Setup
Gizmo, What setup did you finally end up using? Are you up and running now?
Old 06-07-2005, 10:13 AM
rsecret is on a distinguished road
Best Taig setup?
I plan to order the Taig CNC ready unit from Carter. When it comes to the drives I am not clear if I should go servo or stepper? I would think that a closed loop servo setup with encoders would be fool proof but steppers seem to more popular. Is it a cost factor and if so is a servo system that much better?
Thanks for your help!!!
Old 08-04-2006, 06:35 PM
crease-guard is on a distinguished road
TTT.
I am in the same situation right now, deciding servo vs. stepper. Any input is appreciated.
Jay
Old 08-04-2006, 08:29 PM
ZipSnipe is on a distinguished road
Well I asked an engineering buddy who works designing boats for the military and marine patrol, I asked him what the better motor was . He said servo,s becuz they move in a continuous motion where as steppers count the steps in their movement. But what do I know? either would probably work well for my situation and yours.
Old 08-04-2006, 08:49 PM
It sounds like servos for the TAIG is overkill...but if it means I can leave the piece unattended and go do something else, then I'm more than willing to spend the extra money. I'm not interested in speed as long as I don't have to stand over the thing and watch it for 2 hours. I want to be able to set it and leave it until I need to change the tooling.
Jay
Old 08-04-2006, 11:02 PM
metalbyter is on a distinguished road
Smile Taig mills
Yes servos for a taig mill are over kill.
I have a CNC ready taig with a hobby CNC board and mach3 moving 200 oz/in steppers, my rapids are set at 45"/min but it I have tried it at up to 75"/min with no lost steps that I have been able to detect.
The bottom line is you are not going to cut anywhere near these speeds
and I don't think taig recommends rapids this fast for these machines.
I do run mine unattended,I use it for small production runs up to 500 pcs,
and I do get better than .001 accuracy.
My machine is set up at 16000 steps/ inch which is .0000625"/step.
IMHO any more really isn't worth it for me on a machine of this size.
No, servos don't step but the resolution is still limited by the encoder
Mark.
www.microtools.ca
Old 08-05-2006, 02:40 AM
itsme's Avatar
itsme is on a distinguished road
Jay, I have got steppers on my X1 Micro Mill. After recently standing for over 6 hours non-stop 'supervising' a part I was making, I can tell you that steppers won't stop you from leaving the machine unattended. The lack of a decent coolant system will!
Regards
Warren
BTW, 6 hours standing in front of a machine clearing chips and spraying coolant by hand can get boring (who would've guessed?). I'm definitely going to look into flood coolant one of these days...
Have a nice day...
  #11   Ban this user!
Old 08-05-2006, 03:21 AM
Good advice. I'm just at that point where I'm ready to buy but I don't want to turn around in a couple months and say "damn, wish I had gotten 'x' instead of this". I'm trying to figure out exactly what 'x' is right now. I'll mainly be cutting plastics and aluminum. I doubt there will be any steel milled on this machine. I might give it a try, but softer stuff is what I'm after right now.
I'll definitely look into an enclosure and coolant system.
Jay
Old 08-08-2006, 11:23 PM
Moderator
I think if you can afford the extra work and money, servos are worth the extra investment in the long run, but they are not an imperative. If you design and build your stepper system correctly it should work without missing steps, but it may not be as smooth and run as quickly as a servo system.
Halfnutz
Ball screws for Taig mills. Anyone? Idle hands Taig Mills & Lathes 3 12-26-2009 05:55 PM
Mini mills in Europe ? elenabux Benchtop Machines 19 08-26-2005 02:18 AM
Mini mills from china - conversation to cnc? oskars General Metal Working Machines 5 02-18-2005 01:15 AM
where to find links about integrating mini mills with robot gv71 Benchtop Machines 5 01-23-2005 03:35 PM
where to find links about integrating mini mills with robot gv71 RC Robotics & Autonomous Robots 0 01-18-2005 12:06 AM
