Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 11-20-2009, 01:09 PM
Anokiernan is on a distinguished road
Filling tubular taig components with lead?
With a more powerful motor in place and counterweighted, and new 387oz-in steppers outfitted to my taig mill, my next obstacle is tackling the machine rigidity.
I've seen posts about filling benchtop machines with composite epoxy concretes, but have never seen anyone attempt to fill a machine with lead. I have access to an abundance of lead ingots (~4 tons) and a few small melting pots. This all just occured to me while at work, but does anyone recognize any potential issues with filling the taig mill's y and z columns with lead?.
The only issues i've thought about have been shrinkage as the lead cools, and the OEM z column support may become inadequate to hold the column in place. Any other ideas?
Old 11-20-2009, 01:34 PM
The shrinkage will likely be a problem in that the lead will be loose so it will not do a lot to dampen chatter.
However, I think a potential problem is the heat. If the castings were not stress relieved before the machine was made you may finish up stressing releiving when the molten lead is poured and and that could be bad news.
I know the melting point of lead is actually below the temperature for stress relieving but you would have to overheat the lead to make sure it filled all the crevices; in fact you almost have to get the castings up to the lead melting temperature which means part of the cast where the hot lead first contacts are probably going to be well above.
Old 11-20-2009, 04:03 PM
MattTheNoob is on a distinguished road
There is a product used my gunsmiths and such, "castaloy?", maybe, that is poured into the chamber of a rifle to produce an exact mold. I'm not sure of the density, but it has a melting point low enough so as not to affect the chamber material, and little or no shrinkage (I think). Probably too expensive for the amount you'd need to fill up a mini-mill, but maybe worth looking into.
How about lead powder or small shot, packed in tight. For dampening vibrations, you may actually be better off with a non-solid.
Old 11-20-2009, 05:12 PM
The product used for gun molds is probably one of the typemetals that used to be used for casting typeface for printing before photo-offset was developed. There are innumerable formulations and some actually expand when they solidify so they make a very good impression of the mold. However, they are expensive and have all manner of nasty things in them like bismuth and cadmium; not really advisable for fooling with at home.
Old 11-21-2009, 09:33 PM
mactec54 is on a distinguished road
Just put lead shot in it that way it does not shrink & you don't need any heat, sand is good to & works well
Mactec54
Old 11-22-2009, 08:43 PM
Kinda like a "dead blow mill".
Old 11-23-2009, 10:41 AM
rowbare is on a distinguished road
I have a Taig as well. I am thinking of doing an E/G fill for the column. Since you have the lead, perhaps you could cut a chunk that will fit inside the column and then use epoxy to hold it in place.
I don't know how to do the base though. It is capped at both ends.
bob
Old 11-23-2009, 08:01 PM
bob
I'm probably going to try a variation of this. The Y-axis column actually has a gap at the front in which I could pour whatever media I choose into. The tricky part is the Z Column, which is completely open on the bottom. If I'm successful in dampening the taig more I'll be sure to post up the results...
Old 11-23-2009, 09:21 PM
CalG is on a distinguished road
If you have the lead.
just pour in small batches Layers if you will. shrinkage will be filled in by the subsequent pour. heat will be lessened as well.
Go for it!
Old 11-23-2009, 10:12 PM
bostosh is on a distinguished road
Great idea to use lead
Just pour the Pb in in small quantities,
what is your melting capacity? 5-10lbs?
new (hot) will melt/bond to old (cold)
Smaller volumes will not shrink that much
Make a "Kirksite" type mix
I've used this in 1oz to 4000lb molds
very stable stuff
Been doing this too long
  #11   Ban this user!
Old 11-24-2009, 08:14 AM
very stable stuff
Yea 5-10lbs is about right, it's been a while since I've dug it up. We used to use it in conjunction with a spin caster. Both systems have been just sitting around collecting dust as of late, it's a shame. With some rough calculations, the lead should add about another ~60lbs to the mill, nearly doubling it's mass. I'm looking forward to trying this
  #12   Ban this user!
Old 11-24-2009, 11:44 AM
I am not sure how you have your Taig mounted but here is another idea for some of that lead you have available:
http://www.nyccnc.com/Herbie/HERBIES...eight_Box.html
Newbie- Thinking about tubular steel Dman65 DIY-CNC Router Table Machines 1 08-02-2009 09:31 PM
Mixing Lead screws on a Taig setup using Mach 3 gunlocators Taig Mills & Lathes 4 11-08-2008 12:38 PM
Taig - Wandering mill, Lead screw? bluumax Taig Mills & Lathes 123 05-23-2008 06:14 PM
How can I creat tubular 3D enteties(with arcs) PeteGallo General CAM Discussion 21 08-07-2007 09:12 AM
Casting silver in a tubular shape Konstantin Casting Metals 4 07-22-2004 08:15 PM
