| Taig Mills & Lathes Discuss Taig machine here. |
I have avoided cutting any steel with my Taig till now. I have a piece of 1/4" x 1/4" square bar stock that I want to square up on the mill. I am planning to use my 1/4" cutter to do 2 passes per end. Should I use the slowest spindle speed? |
| Is your cutter 2 flute or 4 flute? Carbide or HSS? These things will help you get an answer you can use. Dean
__________________ Taig Shop Projects: http://www.deansphotographica.com/machining/projects/projects.html |
| 5artist: I started cutting steel with my taig about 6 months ago and have been pleasantly surprised with it's capability. I've had no trouble with 12L14 or 1018. I've also done a bit of 4140, which works, but is notably tougher. You NEED to use carbide. HSS just don't last. You'll also need coolant and a way to clear chips. I use the altrax 1/4" 4-flute carbide endmills from enco and run them at 5 IPM, 0.02" DOC @ 1500 RPM.
__________________ Tormach PCNC 1100, SprutCAM, Alibre CAD |
| hsm on steel | seawolf217 | General Metalwork Discussion | 9 | 06-06-2009 08:17 PM |
| Need steel | Tony611 | Hobby Discussion | 4 | 11-25-2008 07:38 AM |
| New Machine Build- 2nd CNC - Steel and MDF? | tvdbon | DIY-CNC Router Table Machines | 4 | 06-09-2008 09:25 AM |
| RFQ 12 ga and .250 steel cut | fastimes | Employment Opportunity | 3 | 03-16-2007 12:33 AM |
| How do I cut steel? | samualt | DIY-CNC Router Table Machines | 8 | 06-30-2004 11:49 PM |
