Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
View Poll Results: What kind of way lubrication do you use?
Petroleum based oil 21 72.41%
Synthetic based oil 6 20.69%
Other, please indicate in post reply. 2 6.90%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 09-02-2009, 06:47 AM
protrackcorp is on a distinguished road
Cool What type of way lubrication do you use on your Taig?
Please indicate petroleum or sythetic base and trade name if known.
Old 09-03-2009, 06:30 PM
Dean W's Avatar
Dean W is on a distinguished road
Well, it's been 24 hours since the poll started, and so far, it looks like only five of us use any oil at all.
Dean
Taig Shop Projects:
http://www.deansphotographica.com/machining/projects/projects.html
Old 09-04-2009, 02:04 PM
5artist5 is on a distinguished road
I use ATF. Not sure if it's synth. or not.
Old 09-05-2009, 05:38 PM
RayGannon is on a distinguished road
I use ATF. That's what the people who sold me the mill said to use and it seems tor do the job well enough.
Old 09-05-2009, 07:36 PM
doanwannapickle is on a distinguished road
Silly me, I've been using way oil.
Old 09-06-2009, 02:57 AM
japroach is on a distinguished road
mobil vactra, which says its petroleum based.
Old 09-06-2009, 07:25 AM
philbur is on a distinguished road
Don't know, what ever comes to hand, but usually from the drum that says "Way oil" on it.
Phil
Old 09-11-2009, 09:13 AM
noisillator is on a distinguished road
Onhy had my Taigs for a short while, but so far, ATF is working well.
Old 09-11-2009, 02:23 PM
Dean W's Avatar
The head stock on my Taig lathe says "Lubricate lathe SAE 10W Motor Oil". That's from the people who make the lathe, so that's what I use on both the lathe and mill. In one of my older Taig factory documents, it says use ATF.
So, I guess if you pick one and stick with it, you'll be doing what the manufacturer recommends.
Dean
Taig Shop Projects:
Old 09-14-2009, 02:45 PM
Astroguy is on a distinguished road
I use non detergent 30W mixed 60/40 with WD40.
  #11   Ban this user!
Old 09-19-2009, 11:58 PM
Speedygonzales is on a distinguished road
transmission oil... thats what taig told me to use.
  #12   Ban this user!
Old 10-05-2009, 11:53 PM
MechanoMan is on a distinguished road
I actually found ATF didn't work so well. It's so thin that when you run at high IPM, the leadscrew will sling it off. Plus it doesn't cling really well and the top of the leadscrew seems pretty dry to me.
I switch to 10W30 oil and I think it's better.
Taig way lubrication CS900 Taig Mills & Lathes 10 06-26-2008 02:37 PM
ADDING BED LUBRICATION thegeekineer Benchtop Machines 3 12-20-2007 09:51 PM
X2 maintainance/lubrication Pretorien Benchtop Machines 3 11-08-2007 07:17 AM
Lubrication bohica Industrial Hobbies (Support forum) 17 04-29-2007 02:13 AM
Lubrication BeerFizz Benchtop Machines 5 11-09-2005 07:25 PM
