| Taig Mills & Lathes Discuss Taig machine here. |
Sunday, I cut my first part out of aluminum. In the end, everything came out great. However, I e-stopped the program early on to edit the code and restart. The reason was that the first plunge at 2.5ipm with a 1/4" 2 flute endmill made the little guy shake violently. I think it was on 2600 rpm. I changed the code to plunge at .3 ipm and it liked that better. I don't know if I need an endmill that can plunge better, or if I should just learn to program the machine to ramp its way into the material. My cuts were about .060 deep and I cut at 5ipm, with about a .125 stepover. That part seemed to work fine, I actually feel like I was a bit conservative there. Even at .3ipm the plunging seemed to put the most strain on the machine.
__________________ DISCLAIMER: I'm a noob :) |
| Even with a center cutting endmill plunging straight in can make a machine shake if it is not really rigid. Unlike a drill and endmill does not have a tapered point that tends to self center so the endmill tries to walk around the center web which does not cut efficiently. The best approach is to ramp in either with a circle or straight line; or drill a small hole and plunge down that.
| Thanks for the replies. I will figure out how to do the ramping next time I cut a pocket. Yeah, I decided that I'll probably build my enclosure with flood coolant a lot sooner than planned. I underestimated the mess it would make, and manually squirting the cutting fluid through an hour long program gets old REALLY fast. I don't plan on cutting a whole bunch more aluminum before I do this mod. Oh, and walking barefoot in the garage is a thing of the past now too.
I'll post up with the enclosure project. I've been looking at other people's setups trying to get ideas. Fretman has a really nice looking one. I'll start another thread when I start planning more seriously. Tuesday night I ran the same part again (I needed 2). My buddy at work gave me a 3 flute endmill that has kind of a void in the middle. There's probably a term for it, but I'm not familiar with it. It plunged into the aluminum like butter. The 2 flute left a better finish at the bottom of the pocket, but that particular 3 flute was able to plunge without chattering at all. I still plan on learning to write in a ramp function though as a normal practice as others have suggested.
| This part was for work, so I programmed it there where I have access to Mastercam. I've been looking at some more affordable programs to use at home. I tried this part with the vectric demo, but it kept wanting to surface the top of the part instead of just going straight to the pocket. Maybe it was because I was using cut3D and not cut2D...
#10
| 0.3ipm is ludicrously low. Higher RPMs may help. Chatter can also be due to your mounting solution not being tight enough. Lubricant is a good thing. Don't worry about the mess. In fact just spraying down a part with a water-based cutting lube in a sprayer beforehand is better than nothing. See the problem is that if you gum up the cutting surfaces with aluminum, things get real bad real quick. The cutting power goes to zero and it just melts more on, as pressure increases as it tries to move into work it can't cut, you'll probably break the tool. Lube can prevent this. Also any methods that improve chip clearance- helixing in, using flood coolant, or compressed air- can improve it. |
| Trying to find out how fast can tap aluminum | REVCAM_Bob | CNCzone Club House | 6 | 06-25-2009 06:57 PM |
| Routing Aluminum as fast as I can? | Imperium | General Material Machining Solutions | 5 | 10-17-2007 09:11 AM |
| RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED - | JavaDog | Employment Opportunity | 6 | 11-17-2005 03:25 PM |
