Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 06-19-2009, 11:53 PM
noisillator is on a distinguished road
Gecko G250s VS. G540
If I buy three Gecko G250s, will they provide the same functionality with Mach3 as three channels of the G540? I don't need spindle speed control or a fourth axis.
Old 06-20-2009, 01:21 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Noisillator,
You will need a BOB (breakout board) other than that the G250 with provide the same stepper motor functionality.
The G540 has a charge pump, the G250 does not.
There are a few breakout boards that have a charge pump.
It is a nice safety feature.
If you don't want to use IDC cables or connectors you may want to consider the G251 instead of the G250.
The G250 has a IDC header.
The G251 has a screw type terminal.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-20-2009, 10:58 AM
Originally Posted by jalessi View Post
Noisillator,
Who sells those? I don't see them on the Gecko site.
Screw terminals are a little easier, of course, but I can work with either type. Are these two driver boards essentially the same otherwise? The G251 is said by Gecko to be a "miniarized version of the G201," whereas the G250 is described as "the drive that forms the control interface of the G540." Because of this, I just assumed there were differences other than the connector interface.
Old 06-20-2009, 11:00 AM
ger21's Avatar
The G250 and G251 are the same drive. The G251 is a G250 with a heatsink and screw terminals. The G540 uses the G250, as they plug directly into the motherboard.
Old 06-20-2009, 03:09 PM
jalessi's Avatar
Post
Noisillator
If you decide to use the G250's be prepared to spend some serious money for a breakout board unless you can make your own.
http://www.candcnc.com/EZPlug250-5.htm
I would use the G251 and one of these.
http://www.kelinginc.net/KL-DB25.pdf
Jeff...
Old 06-23-2009, 09:06 AM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
Also keep in mind that the G540's built in BOB is optically isolated. Optical isolation is a necessity in my book. It is also plug and play. A great value really. Everyone I have sold has made the new owner very happy.
Jeff Birt
Old 06-24-2009, 12:34 AM
phomann's Avatar
phomann is on a distinguished road
Hi Have a look at this thread here. I've done a schematic for a 4 axis system that uses G251s. You may find it useful.
Engineering Note for a 4 Axis G251 Controller
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com
Old 06-24-2009, 02:06 AM
Noisillator
Jeff...
Well, the G250s would actually fit my situation better. In fact, after reconsidering the G250s VS. the board from HobbyCNC, I now realize I have an old power supply that could be modified if I use the G250s. The supply is in a steel case with a fan on the back, and two sides of the case have large, finned heatsinks mounted. All the controller circuitry would fit inside the case, and the G250s could mount directly to the existing heatsinks (with appropriate insulators).
The thing is, this supply isn't a good fit for the HobbyCNC board. It was originally a commercial design specified at 13.8 VDC at roughly 40A. I inspected the transformer this evening, and its centertapped secondary measures about 33.5 VAC without a load. That means it can produce either 24 VDC using a full wave rectifier, or 47-48 VDC with a full wave bridge. The lower voltage isn't enough for either controller, but 48V is just right for the Geckos. That means this supply could narrow the cost difference for me between the two systems. Aside from that, it's been hangin' around the house for nearly 10 years. I've just been waiting for the chance to turn it into something useful.
Thanks for the tip on the Keling KL-DB25 BOB. $25 and it's even opto-isolated!
Need Help!- Gecko G540 rotger Servo Motors and Drives 0 06-02-2009 01:43 PM
gecko g540 Teyber12 Benchtop Machines 3 05-31-2009 03:23 PM
New stepper for Gecko G540 Kelinginc Product Announcements & Manufacturer News 7 01-29-2009 11:18 AM
Gecko G540 from Xylotex gadman58 Gecko Drives 1 01-19-2009 01:37 AM
Gecko G540 and 2 powersupplys possible ? isvflorin Gecko Drives 5 12-20-2008 08:50 AM
