I have a Taig C4 lathe (no mill yet) I am looking to use 2" OD aluminium rod - 6062-t6 & 6082 - T6 From the rod, I will be cutting approx 50mm and I need to drill/bore through this depth removing around 40mm, basically, this will leave me with a tube that has a 5mm wall.
Clearly, that is a large amount to remove and currently I am initially boring out holes from a small 3mm diameter up to around 1" then I take that up to 40mm using my boring bar. As you can appreciate that is a slow process and I was wondering if there was a more efficient method of removing such a large amount of stock?
LinkBack URL
About LinkBacks
