Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: What is the best method for boring large holes in aluminium bar?
  1. #13
    Feb 2009
    UK
    Well, I suppose I'm lucky in being a child of the 70's in that I was tutored in imperial and was there when metrication came in so I was schooled in that also, but I agree that working in both can lead to confusion. I do tend to flip between the two, haha, sometimes even on the same measurement, I have been known to ask for stuff like, cut me a piece 2mm over 18" please.
    I originally sourced my alu from metals4u, but for reasons of the alloy and the markings caused by the extrusion process mean that the anodised end result is not flawless (but not terrible either)
    According to a table I read on various alloys, (http://www.asminternational.org/pdf/...eets/al392.pdf) it seems 6061t6 or 6063t6 is my ideal metal.
    You are right in saying that 2" with 1/8" wall is commonly available, and that is what I use for the inner part.
    I am struggling to source however a tube to cover my needs of 53.8 finish OD and ID of 48.8mm. This would equate to a tube of slightly over 2 1/8", so 21/4" realistically and the OD of this is 57.15mm so take away 2x3mm wall and it is too baggy on my first part. So it would have to be a tube 2 1/4 with min of 1/4" (6mm ish) wall to suit. I can't find a tube at 2/14" x 1/4" in 6061 or 6063 alloy anywhere, this is why I feel I'm stuck with the problem of all that machining.
    Also, thanks for the offer to forward supplies on to me, it's appreciated.
    If this were a timber project, I could easily use a holesaw to remove the inner waste from the timber. I assume there is no equivalent to a holesaw in the metalworking world? would be cool though as I could also use the resultant slug instead of my current useless mountain of shavings
    Regards
  2. #14
    Mar 2003
    Shelby Twp, MI....USA
    I've drilled aluminum plate with a hole saw. Maybe one of the single carbide tooth type might work for you?
    Attached Thumbnails Attached Thumbnails What is the best method for boring large holes in aluminium bar?-le25469-69hc-3.jpg
  3. #15
    Feb 2008
    UK
    Try here? they list 1 3/4" upto 1/4" wall and 2" dia upto 1/2" wall? Worth a call in case?
  1. Drilling/boring aluminium in the lathe
    By kong in forum General Metalwork Discussion
    Last Post: 06-09-2010, 09:45 AM
  2. Need Help!- large size aluminium(6061) machining
    By sharathchandar in forum General Metalwork Discussion
    Last Post: 07-22-2008, 09:57 PM
  3. Drilling large holes in aluminum
    By watsonstudios in forum General Metal Working Machines
    Last Post: 05-03-2007, 08:55 AM
  4. Need help with T-Slots - Boring holes
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 11:39 PM
  5. Cutting Large Diameter Holes in Aluminum Plate
    By barkster in forum General Metal Working Machines
    Last Post: 04-07-2004, 06:44 AM
