Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 06-12-2009, 09:39 AM
2_many_hobbies is on a distinguished road
New Lathe Motor
I found a PMDC motor and would like to ask you guys if I should buy it so I don't waste $150 on it.
Dimensions in inches: 6.5 (w\shaft) x 3.5 round
Weight: 4.85 Lbs
Motor Type: 2 Pole PMDC
Rated Volts: 42 VDC
Rated RPM: 4000
Rated Power: 250 Watts
Rated Current: 8.4 A
I already have a 3/8 XL timing belt at 3:1 that I can throw it onto but I previously bought a 12V 15A 70% efficient motor which is 250W and it is VERY week and cant handle a tool or even spinning a large mass on the lathe.
Should I buy it?? It looks twice the quality of the 12V one I have, thanks!
Old 06-12-2009, 09:48 AM
LeeWay's Avatar
LeeWay is on a distinguished road
That is a bit of cash for such a small motor.
Unless you want a perm mag motor for some reason.
My small DC motor on my lathe cost about $25 IIRC. The controller for it and heat sink was around $100. That and a DC06 board from Homann designs all works great with Mach 3.
Less than $200 all in.
80/20 benchtop lathe build
Lee
Old 06-12-2009, 09:55 AM
Al_The_Man's Avatar
I agree that is a bit steep to pay for that small a motor, even MotionTek Canada who advertise on this site have new motors much cheaper than that.
They come in 90vdc version, so if you want to use as a spindle you can use one of the KB or Baldor SCR drives off ebay etc direct on 120v mains.
Old 06-12-2009, 08:31 PM
The only other motors Ive been able to find are ones like this 1.5HP 48v 4,600RPM but its only 4" round and 4" long so I question its capabilities.
The main problem with ebay for me is $50 for shipping kills me, anybody know of a place in the lower mainland (vancouver, british columbia area) that I can get used/new dc motors for <$100?
As for controllers I build my own, Ive got a stock of 400V/50A fets I make H-Bridges out of that can handle almost anything and their only $2/each
Old 06-12-2009, 08:56 PM
Al_The_Man's Avatar
What size/torque are you looking for? I have a fairly large DC servo with tach on Kijiji right now, I could let it go for $75.00 shipping included to BC.
ElectroCraft 4" dia x 7" length 5/8" dia shaft.
Old 06-12-2009, 11:27 PM
The motor I have on right now is a 1/4HP AC and I defiantly wont go lower than that, Im looking for the 1/3 - 3/4HP range.
Doing a HP = Torque (in-lbs) x RPM / 63025 and converting (16 oz-in = 1 in-lb)
I would like at least 500oz-in @ 500RPM (1/4HP @ 500RPM) but I do the majority of turning at 1000 to 1500RPM.
What are the spec of your DC servo? I currently have a 48V 7.7A and 24V 25A power supply. Thanks!
Old 06-13-2009, 09:25 AM
Jeff-Birt's Avatar
Jeff-Birt is on a distinguished road
Guys keep in mind that you need a continuous duty rated motor. The stock Taig motor will produce 1/4" continuously. Many cheap motors and servo motors are rated at peak torque, the continuous duty torque is much, much lower, maybe 1/4 the peak rating.
I've been looking at getting some custom PMDC motors made for the Taig and have to say that $150 is not a bad price for a good motor. You can of course get lucky on Ebay, or buy a cheap motor and expect to replace it often.
Jeff Birt
Old 07-03-2009, 12:53 AM
One of my spindles is dedicated for engraving, it uses the stock Dremel collets and nut but on my own spindle with angle bearings and much higher precision.
I dont know what kind of Brushless DC motor to get to drive it though, Ive found:
http://cgi.ebay.ca/Aeolian-GT-Sensor...3%3A1|294%3A50
Would spin at 52,000km @ 12V and geared down 3:1 should make it plenty powerful for all my engraving needs (the odd milling pockets into 0.080-0.125 sheet aluminum) but it might sound like a router at that speed, theirs 800kV motors but I don't know if they would be powerful enough.
What one should I choose? My spindle is 4" long, 1.125" round and takes 1/32-1/8 bits
Also how would I interface those types of controlers into mach3? Would i need to make a pic that outputs the 16,000Hz PWM signal and takes in mach3's pwm?
Old 10-07-2009, 12:23 PM
Schweinhund227's Avatar
Schweinhund227 is on a distinguished road
Question
Just bumping this post !
I too would like to know how to control a Servo Drive with Mach3 ??
Since I just aquired "Al_the_man" ElectroCraft DC Servo on Kijiji !
and would also need info on In Line Breaking circuits !
Thanks in advance !
Keep this thread going !
Norm
out
9x20 lathe motor wiring pic? ZipSnipe General Electronics Discussion 7 05-17-2009 06:41 PM
Need Help!- Servo motor for Lathe & 4th axis skip20 Mini Lathe 6 04-16-2008 11:02 AM
Lathe Motor Failure Hackman Mini Lathe 5 09-14-2007 12:38 PM
Taig lathe motor kong Mini Lathe 5 07-06-2007 08:45 AM
Need help wiring a lathe motor chola General Electronics Discussion 3 04-15-2007 10:58 AM
