| Taig Mills & Lathes Discuss Taig machine here. |
| Well im a newbie here at cnc forum. Nice site. I got my wife to let me buy a taig mill cnc with the larger table and a laptop and controller ect. NOW how do you run this thing LOL. Oh yeah she even let me put it in the Kitchen on the table (of course i put cardboard underneath it) What a sweetie. Anyhow i have to become a computer cnc expert real quick. Any tips? I never used mach 2 but have a little cnc experience. thanx ibrew54@rogers.com |
| What controller did you get? Mach3 will not work on a lot of laptops due to the power-saving chipsets not dealing out the timing consistency required for the task. That timing consistency was not guaranteed within the parallel port specification, it's not necessary for running printers. If you have this problem, you can get stalls at unpredictable times even if the speed it turned way down. A stall as the Z-motor lifts upwards is common and very bad since, unless you have some sort of limit switch, it will misunderstand where the Z-axis is and drive the bit through the table. Not all laptops have this problem. A USB-to-parallel-cable adapter will not fix the problem, it makes it worse. A SmoothStepper will definitely fix the problem. I never got satisfactory results with my desktop PC running Mach3. I had to switch to SmoothStepper. |
Smooth Stepper? HM i think in in for a learning curve. I am running mach 2 on this unit> I have to get it all figured out yet. No instructions or book came witjh it and i dont even have a mach 2 book to look at. thanx Mike |
| Madman Mike, This may help a bit. http://www.machsupport.com/docs/Mach3Mill_1.84.pdf http://www.machsupport.com/videos.php http://www.machsupport.com/forum/index.php Welcome to the Zone, Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Mike, Mach2 can be upgraded to Mach3 for no charge, just download Mach3 http://www.machsupport.com/downloads.php Make sure you save a copy of your original Mach1Lic.dat file. See attached jpg to attach pictures. Jeff...
| The question is also what controller box you have there. You've got a computer, and a mill with stepper motors on it. There's a box with a parallel port plug on one side and stepper motor plugs on the other. What is in the box is is very important. Some are put together by amateur mfgs and have no labeling on them but nonetheless there's gonna be a board from a specific mfg in there. |
| hi Madman. where are you located in Canada? im in Toronto, still a nub, dont have equipment but I want to see one of these smaller cnc's in person. good luck regards Mike Last edited by Speedygonzales; 06-08-2009 at 02:51 PM. |
#10
I live in the kitchener waterloo Area.I guess i have to ??take apart the control box and >> what look inside for the mane of the controller printed on a circuit board or something? What type of controller shpould i have for running mach 3?. I think the controller I have is the one that Taig sells to the Public. The unit did come from Taig directly i think. |
#11
| You have a MicroProto 2000 or 3000? The controllers on those are fine and should work as is with Mach. If there is any part numbers or such on it (or post a picture) someone might be able to tell you what it is. If you need to replace it look at using a Gecko G540. They are a nice 4-axis stepper driver that is a great match for the Taig: http://cnczone.com/products3.aspx . I'll be releasing a complete 4-axis drive box using a G540 in the next few weeks as well.
__________________ Jeff Birt |
| Ok so I bought the standard today | Smitty911 | Alibre Design | 1 | 08-24-2007 02:20 PM |
| Just bought a Taig - can anyone help? | ClemsonGirl | Taig Mills & Lathes | 22 | 02-27-2007 07:14 PM |
| New Mill Today | drill | General Metal Working Machines | 2 | 12-25-2006 10:39 AM |
| Anyone bought a Taig CNC from A.Rotondi Engineering? | juaumu | Taig Mills & Lathes | 2 | 06-28-2006 01:40 AM |
| Bought my machine today!!! | gto7419 | Benchtop Machines | 5 | 04-21-2006 11:40 AM |
