Results 1 to 3 of 3
Thread: X Axis loose?
    Apr 2003
    Tennessee
    X Axis loose?
    Hello Group,
    I noticed after I was placing a new part in the vise when I moved my part against a stop that I could push the table in the X-axis a very slight distance. How do I tighten up the table to take out that movement?
    I am running the Taig with CNC.
    Also, does anyone know of a place I can get lead free brass?
    Thanks for the help!
    Eric
    Nov 2008
    That could be backlash or it could be where the table's screwed to the motor mount. There'd have to be a lot of backlash to "feel" it like you say because the maximum width of backlash's travel will be (much) less than one thread turn (1/20th in). You wouldn't want to randomly tighten the leadnut without knowing for sure, and knowing how to tighten it.
    Only brass specifically sold as "leaded brass" contain lead, and leaded brass is not a common type you'd find at the hardware store. There are many classes of brass and an infinite number of exact %'s inside the classes. So you need to start with specifying a purpose and work out from there on which type is most suitable and easiest to obtain/afford.
    Jan 2007
    Here's what you need to do: http://www.cartertools.com/nutback.html
    Tormach PCNC 1100, SprutCAM, Alibre CAD
  1. CNC Taig Mill Z Axis loose
    By ecope in forum Taig Mills & Lathes
    Last Post: 02-15-2009, 01:02 PM
  2. Problem- Loose Emco PC Mill 30 X-axis
    By oxford in forum Benchtop Machines
    Last Post: 06-20-2008, 09:44 PM
  3. Problem- loose position
    By reed in forum Torchmate
    Last Post: 05-29-2008, 11:12 AM
  4. I'm gonna loose it!!
    By k-linkz in forum Stepper Motors and Drives
    Last Post: 12-27-2006, 07:15 PM
