Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 04-28-2009, 09:07 PM
mrscheider is on a distinguished road
Vibrations in the Z axis
Guys,
I decided to breakdown the machine and give it a good cleaning earlier today. Now that it's back together, I noticed that the Z is doing that thing that many have experienced. It doesnt bind or stall the motor but any jog speed over 20ipm makes the axis vibrate while travelling down the column. Up the column is no trouble. I adjusted the side shoes following Nick Carters suggestions and it's great until I replace the spindle motor.
I tried doing the adjustment with the motor attached but I couldnt get the vibration out that way. I could try to clamp the shoes and then tighten the screws but will that cause damage?
There's no side to side movement so I don't think it requires a gib adjustment.
Thoughts?
Regards,
Mike
Old 04-29-2009, 03:46 PM
fretsman's Avatar
fretsman is on a distinguished road
Mike,
I've noticed here in the northeast, my mill goes through changes with the seasons. As it heats up and cools down, the axis definitely "loosens" up but the clamping method you use works for me. Just a little trial and error and it's good to go.
Dave
Dave->..
http://tinyurl.com/DLAManufacturing
Old 04-29-2009, 07:36 PM
Hi Dave,
Thanks for the reply. I would go along with that except it was fine until I took the axis apart and obviously put it back together half-assed! lol
I'll try clamping it and then tightening the screws and see maybe if I can tweak it out.
Mike
Old 04-29-2009, 08:32 PM
fretsman's Avatar
Originally Posted by mrscheider View Post
Hi Dave,
Mike
lol! Well that was my "round-about" way of making my point.
I would try clamping a bit more as well and feeling the screw by hand to mke sure it wasn't binding up on you.
Dave
Dave->..
table vibrations/ head vibrations how to adjust chaz6966 Cincinnati CNC 1 02-25-2009 09:42 PM
Vibrations when turning? rka Haas Lathes 11 08-06-2008 08:36 AM
Problem- Haas VF-2 Jog Handle Vibrations NIKITEC Haas Mills 11 05-16-2008 06:19 AM
eliminating vibrations turpija Mechanical Calculations/Engineering Design 101 10-23-2007 11:56 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
