Results 1 to 2 of 2
Thread: Help setting up 4th axis
    Jan 2009
    Nederland
    I have a sherline rotary table as a 4th axis on my taig. But how do I set this up in mach so that I can rotate it in degrees?
    I do know the following:
    the rotary table has a worm gear that need 72 revolutions to make the table turn one revolution.
    The motor is driven by a gecko 540 and has 200 steps per revolution and 10 microsteps per step.
    Can someone tell me what I need to enter in motortuning in mach for this and how to setup mach in degrees for the a-axis?
    thanks, Daan
    Dec 2008
  1. NEED HELP SETTING Z AXIS HOME
    By PSSJEFF in forum Okuma
    Last Post: 02-20-2009, 09:03 PM
  2. Need Help!- Problems in Setting up 4th axis!!!
    By Khalid in forum WoodWorking
    Last Post: 09-08-2008, 11:51 AM
  3. Need help setting up axis...
    By bradtal in forum Joes CNC Model 2006
    Last Post: 01-28-2008, 10:02 AM
  4. help with setting z axis
    By shamus13 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-11-2007, 10:36 AM
  5. loosing z axis zero setting
    By contractdesign in forum Bridgeport and Hardinge Mills
    Last Post: 09-02-2006, 08:28 PM
