Hello, thank you for the replies. I tried my best to work in the variables because of the inaccuracy being so little. I measured the tool with a dial indicator trying to find the widest part of the flutes and that read 0.2497
When finding the edge, I used a backlight until the edge of the flute blocked the shadow. Now, I know thats not the most accurate, but regardless of how close to the edge I do get, I should still be able to return to that same spot.
And while 0.0011 is a very small inaccuracy, it shows up quite noticably on the part because I'm coming down Z 50%, flipping the stock and coming down the other 50%. Yes, this method in itself introduces more variables but keep in mind, It's been reliable this long using the same method, G-code and material. This a completely new issue. To give you an idea of the amount of error, it's about the thickness of an exacto knife blade. Very small indeed.. but if the surface is expected to be one smooth plane, that little change in thickness is very noticable and I have to admit.. a little annoying.
The problem is then compounded by having to sand off that error which changes the thickness from one part to the adjacent part mounted next to it. Again, all expected to be the same level plane.
So should I try to work out this error or is it too small already to improve without hastening wear? A good point which I didnt consider, btw.. so thank you.
Regards,
Mike
