Originally Posted by
jalessi
**********Cave Man Solution************
If your tooling is close to the same length you can set Z zero with the first tool then when you are ready for a tool change remove the first tool, insert the new tool loose in the collet "So the tool will slide in the collet without force". Lower Z axis slowly until it reaches Z zero then tighten collet.
If the tools are longer be careful you don't bottom out before hitting Z zero.
Using built in Mach3 software technology:
1: Setup Home / Limit Switches
2: Setup Auto Tool Zero
3: Use Auto Tool Zero After Each Manual Tool Change
There are many ways to solve your dilemma, others will chime in with better solutions.
Jeff...
