There was a lengthy thread either here or in the mechanical design forum about column reinforcing - I think the thread was based on the X3 but the principal would still be the same regardless of machine. I think the consensus reached was steel rod with epoxy for the column gave the most straight line deflection improvements but as for rotational deflection (that is twisting or torquing the column) improvements the column to base mounting was the weak point. As for the base there were improvements, but not really quantifiable from filling the base with epoxy granite to help deaden high frequency vibration. Quality of cut was the only measure of improvement on the base which is a rather subjective viewpoint.
LinkBack URL
About LinkBacks
