Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 10-16-2004, 07:11 PM
vwgo is on a distinguished road
Question Total Newbie on Taig CNC Mill!!
Through recent dealings I'm now the proud new owner of a 1yr old Taig CNC Mill. The previous owner bought it and was going to do a great many things with it but never did. Now I have it at an OK bargin. To make a long story short, I was planning to go to school for cnc milling before buying one but now here I'am.
I'm learning to write G-code which seems simple enough. My problem is with the programs. It came with MPS2000 ver 2.1 and Millwizard. Other than inputting a line by line funtion using the MDI in the MPS2000 how can I write a full program and input it to the MPS2000?? It will open a .tap file but how do you make a .tap file??
Do I need to buy another program to make a .tap file??
I did download the Mach1 Mill program and I am able to write a program and save it as a .txt file that the Mach program will open and read. But now the Mach program will not talk to the taig. During the past few hours I have learned that there are a couple types of sevros and stepper motors and that they are program specific.
I have the Lamdba Series 1000DX driver that came with it. Is this good or bad? What program works best with it?? Is it better to run a DOS style program or a windows based program.
Thanks for any help you can suggest!
Old 10-17-2004, 12:54 AM
Philip is on a distinguished road
Writing G-Code for Taig
There are a couple of ways to write G-code for your mill. The easiest way is to use the notepad feature or command prompt in Windows. Simply open the command prompt, start a new file and write the code as you normally would. You can use block numbers if you wish, but they are not necessary. Then save the file with a name and a .txt file extention, or a .tap. Then load the program into MPS2000 via the #2 command and select .tap or .txt files and select the file. It will open like any other program. In regard to using Mach 1, I use Mach 2 and it works great. You will however have to configure the ports/pins for your setup. Try the Mach 1/2 users group and talk to Art. He was a tremendous help to me in getting the software configured.
Regards,
Phil
Old 10-17-2004, 08:40 PM
Smile Thanks!!
Thanks for the info. I will try it.
Mark
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 05:07 PM
Taig or Minitech Desktop cnc mill qsacracer Taig Mills & Lathes 8 12-01-2004 04:11 PM
Taig CNC ready setup help?? efreak Taig Mills & Lathes 2 08-24-2004 08:30 PM
CNC Taig mill WOODKNACK Taig Mills & Lathes 8 06-16-2003 11:13 PM
