Results 1 to 6 of 6
Thread: Taig CNC mill: maximum tool's shank size
    Aug 2007
    united kingdom
    What is the maximum shank size for tools used on Taig mill. I see that ER-16 collets accept only shanks of up to 3/8" or about 10mm.
    Does that mean that all the tools with 1/2" (12.5mm) shanks size are no go?
    cheers, dejan
    Registered SpeedsCustom's Avatar
    Sep 2006
    I think 1/2 inch is too big for the taig. The highest I think is 3/8s
    -Jason
    Registered fretsman's Avatar
    Nov 2007
    You can buy arbors that are threaded to screw right onto the threads of the spindle that will hold 1/2" cutters.
    Dave->..
    Jan 2007
    You can use either collets or arbors on a Taig interchangeably. The collets max out at 3/8", the arbors at 1/2".
    Using 1/2" tools isn't generally a problem, though the spindle won't be up to pushing 1/2" mills through difficult materials like steel. 3/8" is about the limit there.
    Jan 2007
    DeArmond / Positive Flow used to have a "slabber" end mill (I think it was 1") which they claimed gave a great surface finish with a TAIG. It was ~$150 and used to be on this page - http://www.positiveflow.com/taigacc.htm - but I can't seem to find it...
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Registered Hunter12's Avatar
    Mar 2008
    I use 1/2" endmills with a 3/8 shank. I'm only working in aluminum, and it takes it no problem.
    1. Replies: 2
      Last Post: 12-30-2008, 11:14 PM
    2. Taig/Seig Mill physical size
      By praetor in forum General Metal Working Machines
      Last Post: 04-05-2007, 10:58 AM
    3. Maximum size for center screw
      By johnnydoughey in forum Mechanical Calculations/Engineering Design
      Last Post: 11-29-2006, 07:35 PM
    4. New Taig, 8 ipm maximum rapid speed?
      By fivaxis in forum Taig Mills & Lathes
      Last Post: 05-11-2006, 09:55 AM
    5. The maximum size is 3000 bytes.
      By vacpress in forum Forum Questions or Problems
      Last Post: 04-03-2004, 09:39 PM
