Results 1 to 6 of 6
Thread: Some new toys for my Taig
    Registered fretsman's Avatar
    Nov 2007
    Laser jig is finally setup
    This is a simple laser jig setup that I "lifted" from Greolt (Greg) from here at the CNC Zone. He shared his macro and I must say I love it for those "not so precise" setups when you just want to find a quick location of material. I have a lazer button setup on my Mach 3 screen and when I have the laser just over the area I want to start cutting, I just click the button and the X and Y travel over to the exact point the laser crosshair previously was. The Laser holder is made from black acetal.
    My vac jig is just about completed and it works perfectly with the 1/8' O-ring gasket. It was made from Nylatron and was free so I can't complain. I'd like to do a longer grid someday but this will do for now. And just so nobody asks, "how the heck is that working?", the black piece of HDPE is just sitting on top of the vac jig to show the crosshairs, it is obviously not being "pulled" down as it's not completely covering the gasket.
    I still want to make some side clamps to keep the material from moving laterally when being machined or engraved. Double faced tape is good but If I can get this to work, which it seems to be, it'll make material changes nuch easier and quicker.
    Attached Thumbnails Attached Thumbnails Some new toys for my Taig-taigheadunit.jpg   Some new toys for my Taig-taigheadunit_.jpg   Some new toys for my Taig-taigcrosshairs.jpg   Some new toys for my Taig-pauseled_bmp.bmp
    Dave->..
    Registered SpeedsCustom's Avatar
    Sep 2006
    Dude! What the heck! Thats awesome stuff right there. I like that lazer set-up. Can't those be taken off from drills etc?
    I rarely use an edge-finder, should start...but still. Lots of times I just line it up with some jogging etc. Thats nice!
    -Jason
    Nov 2007
    Thanks, Jason.
    Actually those are usually 2 single lined lasers that mesh on the table. This is incorporated into one unit. Defintely not the "precise" way to pickup an edge but for just a quick finder, it works great and has that "cool" factor that we all love.
    Dave->..
    Sep 2006
    Sure is cool!
    Still have so much work to do on my taig. I love the taig!
    -Jason
    Registered Teyber12's Avatar
    Jul 2008
    How do you use your vacuum setup? sorry im a noob... Do you place an object on it and pull a vacuum? is this enough to hold down for milling operations? what vacuum pump are you using?
    very nice
    Nov 2007
    Thanks -
    Yes, I place the part down on the grid with the gasket located at the perimeter of the part and turn on the vac and give it a little push down and you can hear the pump change sound as it creates the vacuum.
    I haven't done any steel but I have taken very light cuts with a fly cutter to clean up aluminum and plastics by clamping plates all around the material so that it can't move sideways.
    You can see more of my little setup here:
    http://cnczone.com/forums/showthread.php?t=60058
    Dave->..
    1. Making wooden models and toys?
      By jeffmorris in forum Hobby Discussion
      Last Post: 04-30-2008, 04:43 PM
    2. Taig CNC
      By GCWheeler in forum Mini Lathe
      Last Post: 01-19-2008, 04:19 PM
    3. My new toys...
      By kanankeban in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-15-2007, 07:01 PM
    4. Taig 3 Jaw Chuck on Taig Mill?
      By jim_stoll in forum Taig Mills & Lathes
      Last Post: 09-14-2007, 06:44 PM
    5. Taig CNC help
      By Grimracer in forum Taig Mills & Lathes
      Last Post: 03-13-2004, 10:32 PM
