Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 09-25-2004, 10:51 PM
Deviant is on a distinguished road
Info on Taig Mill Vs others.
Can anyone give me the skinny on the taig mill vs the sherline, imports (homier)
I've read some info on them, but looking for first hand info.
Thanks,
Old 10-16-2004, 04:37 PM
Philip is on a distinguished road
I've been using the Taig mill for about three months now. I have had no problems with it, and it runs flawlessly. I recently re-adjusted the x axis nut because I wasn't happy with the backlash,(.005) but now have it down to .0005! I run the mill via Mach 2 latest version and it is just great. Using Mach 2 you can increase the motor frequencies and get slightly faster rapids. I found that the standard 30 ipm is fine however. Anyway, it has made me many parts already, and it is built beautifully. Hope this helps.
Regards,
Phil
Old 11-26-2004, 06:16 PM
escowizard is on a distinguished road
Thumbs up Taig Miller
I am thinking about a Taig myself...
Can't you compensate for the backlash in the backlash comp?
Also How do you guys feel about being able to cut 5/16 cast iron plates on the rotary 4th pos. ?
Cutting screw machines cams is like doing profile 2D sheets.
Any info would help.
thanks
Never Give Up
Old 11-26-2004, 11:46 PM
WOODKNACK's Avatar
WOODKNACK is on a distinguished road
I also have a taig cnc mill. The more I use it the more I love it!
My Taig Mill
My little piece of the web!
http://users.adelphia.net/~wjdupont
Old 11-27-2004, 05:17 PM
Taig
Have you ever cut any metal around 5/16 thick?
Never Give Up
Taig Mill, US Digital MS23, Controller??? marjamar Taig Mills & Lathes 3 02-07-2007 10:16 AM
Taig mill accuracy dberndt Taig Mills & Lathes 14 12-28-2004 10:36 PM
Total Newbie on Taig CNC Mill!! vwgo Taig Mills & Lathes 2 10-17-2004 08:40 PM
MicroProto Taig Mill vayacon Taig Mills & Lathes 4 10-14-2004 04:58 PM
Master5 Taig Mill Setup Jcadwell Mach Mill 2 11-08-2003 06:53 PM
