Results 1 to 4 of 4
Thread: Taig Spindle LED Light
    Registered fretsman's Avatar
    Nov 2007
    Ok, thought I'd share this as it's very useful if the lighting around your machine may be "shadowy" like mine. I tore apart an outdoor LED low voltage lighting lamp ($3.05 on clearance at Lowes!) that has 6 superbright LEDs.
    In the first pic you can see the roll of tape and how many shadows are on the inside and this gets even worse when you get the headstock down low with a cutter inside and you're trying to move in on a pocket or a similar situation.
    I've seen the LED rings that others made for their X3 mills and thought that would be perfect for me but I'd have to come up with a different mounting idea as there's no room under the headstock for something like this. So a sort of "collar" would have to do. It's made from black acetal 375 thick and the pocket depth on mine is .250 but needless to say, feel free to modify it any way you'd like.
    Sorry I didn't get any pics of the inside of the housing inside but when you see the dxf for it, you'll get the jist of the pocketing for the wires. As for led hole locations, those are totally up to you and the cover cap can be made using the same outside profile as the base. For the wiring, I used a 12 volt wall wart transfomer that is plugged into my main outlet center and turns on when I power everything up. You could add a inline rotary switch if you desire though.
    Just thought I'd pass this along as it's a quick project that really helps out, just don't make these up and sell them on ebay- lol!!!
    Attached Thumbnails Attached Thumbnails Taig Spindle LED Light-0tape.jpg   Taig Spindle LED Light-1tape.jpg   Taig Spindle LED Light-top1.jpg   Taig Spindle LED Light-top2.jpg
    Dave->..
    Nov 2007
    More pics including a pic of the tape with just the spindle light (no shadows!!). Also forgot to mention, I attached this with a screw into the T-slot in the headstock.
    Attached Thumbnails Attached Thumbnails Taig Spindle LED Light-bot1.jpg   Taig Spindle LED Light-bot2.jpg   Taig Spindle LED Light-finaltape.jpg
    Attached Files Attached Files
    Dave->..
    Registered DonFrambach's Avatar
    Nov 2006
    cool!
    Registered SpeedsCustom's Avatar
    Sep 2006
    Cool stuff, Impractical for me because I had spare lights from ikea. But none the less, really cool! I would do this otherwise!
    -Jason
  1. Spectra light and Light machine owners have ?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 07-18-2008, 10:52 PM
  2. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills & Lathes
    Last Post: 09-14-2007, 06:44 PM
  3. Replies: 2
    Last Post: 08-27-2007, 09:08 AM
  4. Fanuc 6t (No CRT,red light)
    By jachilli in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 06-10-2006, 01:20 PM
  5. LED Machine Light
    By KaptainKarst in forum General Electronics Discussion
    Last Post: 02-08-2006, 01:57 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
