Results 1 to 3 of 3
Thread: Problems setting up Taig Mill
    Jan 2006
    So I bought this Taig mill off Ebay several months ago. Didn't have time to mess with it when it came in, so I just got around to setting it up, and boy am I lost. I've hooked everything up, and installed a legal full version of Mach3, but I can only get X and Z to move. Switched cables on the motor that wasn't moving, and it is not the motor. Also, regardless of whether I try to jog positive or negative, the axis always moves positive. I assume I have some pin settings wrong, but I don't know. The mill and controller came with no documentation. I do know it is a Xylotech controller. HELP.
    Feb 2006
    us
    Yeah don,t try to re wire it yourself as I have seen plenty of posts of people frying those Xylotech boards. Sorry this is the only advice I could give ya. Try posting some pics and maybe Al the man will chime in. Good Luck!!
    Jan 2006
    OK, I got the pin configuration figured out, and not can move all axises both possitive and negative. Just need to fine tune the movement and backlash, and I should be good to go. Anybody want to recommend a decent free CAM software for creating G code?
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills & Lathes
    Last Post: 09-14-2007, 06:44 PM
  2. Plasma Setting Problems
    By loopy251 in forum General Waterjet
    Last Post: 05-28-2007, 11:45 PM
  3. Setting up Mach 3 on Taig mill
    By jacmarhal in forum Machines running Mach Software
    Last Post: 05-10-2007, 06:29 AM
  4. Taig Mill, a few problems
    By apullin in forum Taig Mills & Lathes
    Last Post: 03-18-2007, 03:57 PM
  5. problems setting up LVD MNC800 Brake press
    By Xerophobic in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-12-2006, 09:42 AM
