Results 1 to 6 of 6
Thread: Stiffen Z axis on a TAIG mill
    Jan 2007
    Any folks out there seen or done a similar project to this - http://www.engineeringhobbyist.com/p...olumn_support/
    It looks logical; you still have the ability to nudge the Z column for tramming purposes. I'm thinking about doing something like this combined with a 100lb steel plate fastened to the bottom to give it the most rigidity.
    I don't have any specific requirements - just enjoying and experimenting.
    Jan 2007
    As much of a fan of the Taig as I am, there were a couple of aspects about the whole Z column that I never liked either. That being said, a properly trammed and torqued Z column should be able to take about anything the rest of the machine could ever reasonably throw at it. Rigidity has never really been a complaint I've heard as regards the Taigs. As little bench mills go, it is pretty stout.
    Maybe you could simply drill and pin the connection after tramming if you are worried about it simply shifting, but if you really are running the mill hard enough to get the Taig actually flexing, bracing probably won't help - you are probably doing serious enough work that you really should be looking at full-size mill instead!
    Jan 2007
    Stepper - Fair point. I agree if a larger mill is appropriate if you're running it that hard
    Sounds like what you're saying is that the bolt & nut, if properly tightened, should hold the Z axis upright with plenty of torque for the machine. I can't say I've had any problems - but was thinking about overall rigidity and vibrations.
    Any other experienced TAIG users have opinions on this? Is the Z-axis solid as-is? Is this not a worthwhile upgrade?
    Oct 2004
    It shouldn't move, unless it's not tightened enough. Don't over tighten - 40 ft/lbs is way too much, and don't ask me how I know...
    It is important that the mating surfaces be clean, and not lubed...
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Jan 2007
    Nick - is there a trick to knowing approximately how much 40 ft/lbs is?
    May 2007
    Quote Originally Posted by tikka308 View Post
    http://en.wikipedia.org/wiki/Torque_wrench
    1. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 01-23-2009, 12:14 AM
    2. Taig 3 Jaw Chuck on Taig Mill?
      By jim_stoll in forum Taig Mills & Lathes
      Last Post: 09-14-2007, 06:44 PM
    3. new Taig 4-axis mill and EMC2
      By nickydubs in forum LinuxCNC (formerly EMC2)
      Last Post: 02-23-2007, 10:09 AM
    4. Concrete to stiffen mill upright?
      By Tristar500 in forum Benchtop Machines
      Last Post: 11-12-2006, 10:21 PM
    5. How to configure 4th axis for Taig mill?
      By Andy Fritz in forum Taig Mills & Lathes
      Last Post: 06-20-2006, 08:07 AM
