| Taig Mills & Lathes Discuss Taig machine here. |
I have just finished the "Getto" enclosure for my new Taig mill. I was on a tight budget and got it built for $160. I have not used it yet or tuned the motors. I Have the computer I am going to use and am in the process of installing all the software. I did run it manually and it seems fine. It may be a few weeks before I get back to finishing it. Will post update when I do. ![]() ![]() I installed the computer tonight and tuned the motors all went well. I ran g-code for the roadrunner just to see what it would do and everything went well except the X axis was flipped left to right compared to what was on the screen. Also, and this may be a dumb question but where should home be? Should it always be in the same spot for every project? It seems like most of the work is setting up. Is there any videos that show how to get started from clamping down your work piece to the finished part? I have watched all the tutorials but they leave out the very basics and assume you know a bit about setting up already. I have a small manual lathe but this is my first encounter with milling. Last edited by Astroguy; 06-19-2007 at 09:48 PM. Reason: Update |
| Astroguy, Looks good!! You built it very inexpensively (but, not cheaply!! which is good). Are you planning to use a cooling system, if so, flood or mister? And what type of work or "stuff" are going to make. Do post so pic's when you start making chips. Well keep up the good work. Ron |
| Nice! I'm going to need to make an enclosure for myself also. Will be getting the sherline 5400 cnc system, planning make an acrylic box with a vacuum cleaner opening to suck any carbon fibre/g10 dust when milling it. |
| I installed the computer tonight and tuned the motors all went well. I ran g-code for the roadrunner just to see what it would do and everything went well except the X axis was flipped left to right compared to what was on the screen. Also, and this may be a dumb question but where should home be? Should it always be in the same spot for every project? It seems like most of the work is setting up. Is there any videos that show how to get started from clamping down your work piece to the finished part? I have watched all the tutorials but they leave out the very basics and assume you know a bit about setting up already. I have a small manual lathe but this is my first encounter with milling. |
| Config>Ports and Pins>Motor Outputs and click on the Dir LowActive, or in Config>Homing/Limits The reversed column is what you want to modify... Either should work.
__________________ Nick Carter Largest resource on the web about Taig lathes and mills www.cartertools.com |
Thanks for the reply. I got it fixed. |
| My new TAIG and enclosure...also flood cooling ?'s | VTX | Taig Mills & Lathes | 34 | 10-16-2007 12:22 PM |
| My new enclosure | David Da Costa | Commercial CNC Wood Routers | 3 | 10-28-2006 01:03 PM |
| New All In One Enclosure | mlaws1172 | General Electronics Discussion | 5 | 10-20-2006 08:26 PM |
| My TAIG enclosure is here! | Smertrios | Taig Mills & Lathes | 15 | 04-24-2006 06:31 PM |
| My Enclosure please take a look. | Oldmanandhistoy | General Electronics Discussion | 36 | 03-03-2006 08:48 AM |
