| Taig Mills & Lathes Discuss Taig machine here. |
I have A cnc TAIG Mill with the 18" Table, This machine has the CNC Leadscrew nuts. I am getting backlash that I just cannot tolerate as I machine many parts that have bearing fits machined into them. Has anyone installed ball screws on the Taig mill? If so can you elaborate on the process. I am open to listening to any ideas on correcting this problem. Scott |
| I would ask here: http://groups.yahoo.com/group/taigtools/ On my Taig CNC mill I get 0.003" backlash, which from reading the group, seems typical. If you are getting more than that, there are ways to isolate and fix the cause. I've seen a couple of posts from guys who have converted Taig mills to ballscrews (search the group above). From their descriptions, it is not easy or cheap. If it was an easy retrofit I would be interested myself. Ed |
| What do you consider acceptable? I can get .002" or so on mine, and like Edfurg saud .002"-.003" seems typical and realistic. I looked at mine to do a ballscrew conversion on, but it looked easier to me just to use the Taig to simply build another machine from scratch than to modify the stock Taig. Now I have the Taig for most use and a homebrew with ballscrews that I used the Taig to build. Ironically it cost about the same as modifying the Taig would have, as the major cost is in screws and a/c bearings. Easier too, I think. I also scored a seriously beefy used Parker Daedal unit out of a laser optics facility that holds 1.3 micron, or .000051", but that is just getting stupid. It only has a 6" x 6" working envelope, But ground ballscrews and six(!) encoders. Its for sale cheap if you really feel the need something that blatantly insane, or just shop around for surplus if you are in a tech-rich area for something similar. Last edited by Stepper Monkey; 05-04-2007 at 03:14 PM. |
Stepper - Have you posted a description or photos of your mill? Also, send me a PM with details on your Parker Daedal unit. I have an application for a small working envelope mill for engraving. I agree, It would be just as cheap to build a mill using ballscrews. I wish Taig offered a ballscrew version. For a turn-key system, the Syil Products X2 and X3 are the lowest cost ballscrew mills I'm aware of: http://www.syilamerica.com/products.asp Ed |
| I have a brand-new Taig 2018CR-ER and after doing the disassambly-and-nut-adjust featured on Nick Carters Taig pages, I got my backlash to .002". I typically mill symmetrical 1" mold cavities 1/4" deep in aluminum using a 1/32" ball cutter, and the backlash is not noticeable on my resulting parts. Just the same, I tried using the backlash compensation available in Mach3 which dropped the backlash to zero, but it added a crazy ramped decelerator when the axis changed direction, which tended to stall my steppers when used with my gcode and the acceleration I had set on my axes. I couldn't get rid of the funky behavior, so I abandoned the backlash compensation altogether. It is kind of funny - my guage measures thous on a big dial, and a deflection of .002 looked HUGE on it. At first, I thought "Oh Noes!", but then I stopped and asked myself "Will, is it *really* that bad?". It wasn't. |
| I worked with the Taig over the weekend and I was able to get the backlash to .002 by adjusting the lead screw nut. My screw does have some wear in the center as it is now tight at both ends of the travel. All the parts I machine are small so this is not too much of a problem. I am going to order new screws and nuts for both the X and Y axis< when I install these I am going to add a bijur automatic oil pump so I know that they will always be well oiled. Scott |
| Give us an update when you install the new parts. I ordered a new nut for my X axis but have not installed it. The brass leadscrew nut has a boss that appears to be press fitted into the mill. Not sure how to remove it and align the new one. Ed |
| You can press it out, or carefully use a soft punch and punch it out.
__________________ Nick Carter Largest resource on the web about Taig lathes and mills www.cartertools.com |
Did you use this kit? Do you have any pictures of the setup? I saw your thread on the 5 axis Taig and was hoping you'd answer the questions others had for you there. http://www.cnczone.com/forums/taig_m...ig_5_axis.html
__________________ Dave->.. http://tinyurl.com/DLAManufacturing |
#10
In another thread, you wrote: "yes but if i change do The distance of 150 mm machine is moved 149.35 it is sam problem bath i dont no wath" It was a bit difficult to understand what you meant, but it sounds like a problem, and not inconsistent with a backlash error. Was this the same machine you put the ballscrews in? Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
#11
| I'm a bit leery of that site you linked there isn't much info and seems like a lot of the links just don't do anything. |
#12
| That same guy has been spamming the taigtools mailling list. Since he doesn't provide very detailed information (even a photo or a set of installation instructions) I can't expect most people to order from him. I was fighting some bad X backlash on my Taig mill recently and it turned out to be the nylock nut that holds the coupler in place. I reinstalled the coupler and my backlash is around 0.0015" right now. I'm good with that. I also made new coupler tubes (the little plastic tubes) and found an easy source for them. Many Bic-style pens have ink tubes that are the same diameter (just under 1/8", I think it was 0.120"). One pen tube is enough for one coupler. |
| Coming Down to the Taig Micro Mill or Grizzly Mini Mill. | SpeedsCustom | Taig Mills & Lathes | 15 | 01-23-2009 12:14 AM |
| A fix for z-axis backlash on TAIG mills | Smertrios | Taig Mills & Lathes | 2 | 11-18-2007 09:00 AM |
| MicroProto Taig Mill | vayacon | Taig Mills & Lathes | 4 | 10-14-2004 04:58 PM |
| CNC Taig mill | WOODKNACK | Taig Mills & Lathes | 8 | 06-16-2003 11:13 PM |
