Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 04-06-2007, 01:43 PM
conlimon is on a distinguished road
Taig Micro Mill model 2019 Collet & cutter help!
hey all -
i'm a brand spanking new CNC person, and i've just received my Taig 2019 with ER16 spindle. i've installed the stepper motors, and set the mill up, but i don't have any collets or cutters yet. i'm trying to figure out which collets to get, and where to find a basic assortment of end mills. I'm building an airplane, and I bought the mill because there are a host of parts that i need to make, and it's cheaper to buy a mill and learn how to build the parts than it is to get someone to build the stuff for me. Most of what i'll be doing is either aluminum, or acrylic, and i also need a cutter to do text engraving. I'm having trouble trying to figure out which collets fit my machine, and also having trouble sorting through all the different types of cutters. Could someone give me a good starting point for this stuff?
thanks for any help!
cj
Old 04-06-2007, 03:29 PM
cartertool is on a distinguished road
You need ER16 collets. You can buy them from any Taig dealer in a few sizes, or buy a complete set from Enco, MSC, Usshoptools.com and about every other industrial supplier.
Generally you will want at least the 3/8" and 3/16" collets.
As for end mills, you generally need a few different diameters and types depending on the jobs you will do. Again, you can get them from just about any industrial supplier. Make sure the shank sizes match the collets you do buy. Generally 3/8" and 3/16" shank are the most common shank sizes you will use.
Originally Posted by conlimon View Post
hey all -
cj
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
Old 04-07-2007, 05:27 AM
Stepper Monkey is on a distinguished road
Definitely agree with what he said. If you can, just get a whole set of collets, but even if you don't make sure you at least add a 1/8" collet to the two sizes recommended above. I noticed you said you were going to do text engraving, and the standard for engraving bits is always 1/8".
Whtever you do, don't forget to pick up an eludium q37 modulator as well. The left-handed ones work better for the Taigs. You can usually find them cheap from any tool shop that sells good selection of billet stretchers.
Old 04-07-2007, 02:12 PM
Pretorien is on a distinguished road
You're 6 days late
EM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-23-2009 12:14 AM
Taig cutter chatter Rockomo Taig Mills & Lathes 5 02-16-2007 01:03 PM
Taig Micro Mill 2000 steps per unit JV11 Linear and Rotary Motion 4 09-26-2006 08:13 AM
Taig Micro Mill is Wobbling MrRage General Metal Working Machines 4 09-02-2005 11:31 AM
Need help with a HF micro-mill mondo50 Benchtop Machines 3 08-26-2005 10:52 AM
