Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 03-28-2007, 11:09 PM
mcundiff1's Avatar
mcundiff1 is on a distinguished road
Mini mill head on a Taig
Hello all;
I have a Taig mill, and have been happy with it. But I was thinking of putting a Mini mill head assy from Little Machine Shop on it . I would like the R-8 spindle and would get the belt conversion for it. I do a lot of work on Alum, so I need a higher speed range ( 4000 - 8000 rmp ) . I was also looking at Lathemaster mill, but spindle speed to low, and the miil is kinda big from my Apt.
Another idea was get the ER-16 spindle and the Sherline dc motor, add flood coolent and be happy ..........
Thanks guys Mitch .....................
Old 03-28-2007, 11:31 PM
Pretorien is on a distinguished road
Originally Posted by mcundiff1 View Post
Hello all;
I'm a bit puzzled by your approach - I have an X2 (mini-mill) with the belt drive conversion and am looking at a Taig, in part because the maximum speed of the X2 with the belt drive conversion is 4000RPM (not 8000)
There is an optional motor for the Taig that will take you to 10,000 RPM and, since the Taig is available with an ER-16 spindle, the conversion should be easy - finally, I'm not really certain that the mini-mill spindle bearing will handle 10,000 RPM
To my mind, the only significant advantage the X2 has over the Taig is the quill control which allows me to use the mill as a drill press with precise work positioning.
EM
Old 03-29-2007, 12:41 AM
in2steam is on a distinguished road
Taig mill, has that speed range depending upon the motor, it you convert to high speed spindle like many have done you can have alot more. You can get the two pole motor, from carter tool I believe, I am sure Nick will see this post. At anyrate that mill is already capable of 10k with the proper motor, trying to put a different heavier head on the mill is just reinventing the wheel.
It also has the ER16 spindle option which you can order.....
chris
Old 03-29-2007, 03:31 PM
cartertool is on a distinguished road
I bet that the minimill head is even heavier than the Taig head and motor. You will certainly need beefier steppers for Z in that case, and it may place a lot of stress on the z axis (how much does it weigh?)
The Taig CNC spindle runs at 10K rpm in the top speed range.
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-23-2009 12:14 AM
Taig Vs Mini Mill heilcnc Taig Mills & Lathes 1 03-08-2006 10:31 PM
Mini Mill Head Height dropride Benchtop Machines 1 12-03-2005 06:39 PM
More Z travel please, For a Taig Mini Mill MrRage Taig Mills & Lathes 2 11-03-2005 03:46 PM
