Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 02-14-2007, 08:39 PM
Rockomo is on a distinguished road
Taig cutter chatter
Hello All,
I am using a Taig mill, cutting mild cold roll and trying to get a nice flat surface on a piece 1 in by 1.5 in steel. I was taking .001 cuts with a 7/16 HSS end mill on the 4th pully down. It seems like the cutter must me jumping as the surface in not totatlly flat as compared to a Enco mill result at work.
Any ideas.... Spindle adjustments?
..Rock..
Old 02-15-2007, 03:23 PM
cartertool is on a distinguished road
Originally Posted by Rockomo View Post
Hello All,
..Rock..
7/16" is a rather large endmill for the Taig (although in this case you are using it more like a flycutter), and .001" depth of cut is incredibly shallow, which can cause it to skip a bit. Add to that that Cold Rolled can be hard to machine, is full of stresses, etc. and you get a difficult situation.
I would probably use the lowest speed on the pulley, more like a .01" depth of cut, copious cutting oil/coolant on the part with a slow feedrate.
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
Old 02-15-2007, 07:03 PM
Column question
Hello Nick
Thanks for the quick reply. In looking over the mill, and measuring between the spindle head block and the table, I noticed the the whole head assembly can rock back and forth on the vertical column to the tune of .010 inches. This may be part of my problem.
I haven't taken it appart yet.... is there gib adjustment so that the slider for vertical assembly doesn't rock back and forth on the vertical column plate?
Thanks again... ..Rock..
Old 02-15-2007, 08:35 PM
Hello Nick
See here:
http://www.cartertools.com/millset2.html
and here:
http://www.cartertools.com/millset.html
You need to adjust the clamping shoes/gibs on the z-axis.
Nick Carter
www.cartertools.com
Old 02-16-2007, 08:22 AM
Nick... You are the man!
Hello Nick,
Your help is very much appreciated! You got me back on track in very short order. This newbie is very greatful!
T H A N K S ! ! ..Rock..
Old 02-16-2007, 01:03 PM
Bowman's Avatar
Bowman is on a distinguished road
Not sure what your part is going to be used for but if its not a part requiring critical strength you could try annealing it some to soften it up. Just a thought.
chatter using mach 2 jtriggs Mach Mill 5 01-10-2007 05:02 PM
boring bar chatter chipproducer General Metalwork Discussion 21 11-09-2006 11:23 AM
chatter problem bdrmachine General Metalwork Discussion 14 08-21-2005 07:24 PM
Chatter gabeless Hard and High Speed Machining 10 07-14-2005 12:09 PM
Stepper chatter jimglass Gecko Drives 1 06-16-2003 03:02 PM
