| Taig Mills & Lathes Discuss Taig machine here. |
hello fellow EMC and/or taig users, i've recently aquired a new taig 4-axis mill, with shaft encoder feedback. i'm trying to get it set up to run with EMC2, but i'm having difficulties. here's what i've done so far: when i run it in EMC, a BDI that i can only assume is distributed by Sherline since images of their equipment are all over it, i can get all four axes moving and Z and A trigger an E-stop when they move too fast/are stalled. when X or Y are stalled the numbers in EMC just keep moving. i am also unable to turn the spindle on or off. then i downloaded a live CD of EMC2 running in ubuntu. using the standard configuration for a 4-axis stepper i get nothing, it won't move a single axis or trigger the spindle on or off. the only configuration i can get to do anything is the one for the NIST lathe, which does some odd things. when run in the Axis GUI i can control the X axis and the Z axis, but not the A or Y which are not displayed anyway, even though Y is in the config file. however, when i use the Mini GUI the Y axis pops up, it works, and the Z will not allow any movement larger than a click or two in either direction. i cannot control the spindle in either GUI. so, my questions are these: does anyone have a config and HAL file they're using for their Taig that i could start with, since adapting the config for the NIST lathe doesn't seem right? is the feedback from the shaft encoders entirely within taig's control box, and if so why won't it register a stall with the X or Y axes? is there anything about EMC that makes it worth my trouble, other than the supposed ease of setup? thanks, nick |
| I am not a developer. I just play one on tv ![]() if the total message is less than around 24k you can send it to emc-board <at> lists.sourceforge.net You would get extra points and graditude if you added a page with your setup and description to the wiki ![]() http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl sam |
| A call to Kurt at Taig will likely answer any architecture questions you have.
__________________ Nick Carter Largest resource on the web about Taig lathes and mills www.cartertools.com |
| new Taig 4-axis mill and EMC2 | nickydubs | LinuxCNC (formerly EMC2) | 3 | 02-23-2007 10:09 AM |
| Taig 4th axis setup | gabi68 | Mach Mill | 4 | 01-11-2007 12:02 AM |
| Taig 4th Axis Concept | nattyone960 | Taig Mills & Lathes | 0 | 11-17-2006 04:02 AM |
| Taig Z axis stepper screaming! | Andy Fritz | Taig Mills & Lathes | 15 | 06-30-2006 07:50 PM |
| How to configure 4th axis for Taig mill? | Andy Fritz | Taig Mills & Lathes | 5 | 06-20-2006 08:07 AM |
