Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 02-26-2004, 09:23 AM
Grimracer's Avatar
Grimracer is on a distinguished road
Taig CNC help
I received my CNC machine and have it up and running at my home location (Power Surge Racing Products, LLC.)
I have a question.
While running the unit it will sometimes stutter (buzz as if to misunderstand or hang up) and i will loose my 0 position (so far X and y only). I have to press the space bar to get it to stop and then it will start right up again using the (C) key.
I switched steppers with the Z unit and same thing (X travel). the bed is free and very smooth.
Is there a chance that i have the feed rate to high? I'm just testing on bass wood and making .050" cut depths. Is 10 to 24" a minuet to much feed? The unit says it can do 30IPM
seems to me that the feed can be changed in the cam program or the MPS running screen? Witch should i use
Hope you can help and that you understand my question.
Best Regards
Mike
you have the right to ROCK
Old 02-26-2004, 11:12 AM
WOODKNACK's Avatar
WOODKNACK is on a distinguished road
hmmm
try running the program dry. What i mean is all setup so the cutter doesnt actually come down and touch the wood. then run the program. see if the same thing happens. if so then its not the wood! what size stepper do you have on it. how fast can you move around the axis before the stepper start to skip?
Also could be the software you are using! I switched to turbo cnc and have not had any problems. great hobby software.
My little piece of the web!
http://users.adelphia.net/~wjdupont
Old 02-26-2004, 11:56 AM
Grimracer's Avatar
Re: hmmm
Woodknack
First thank you for hepling me out. Here is what i have seen and the info on the machine...I made a rime...
Anyway,
I bought the uint from Microproto and its box stock. Meening the steppers and the driver and the programs offerd with the unit.
Lets see...
MPSPRO (this is the DOS program,,is this the Gcode program)
Millwizard (cam program)
MACHINE SPECIFICATIONS:
Maximum Travel Speed: 30 in/min. (no idea who makes them)
Maximum Travel: X = 12", Y = 5.5", Z = 6.0"
The machine as only done this while not cutting but rather passing over the part to say,,,start a new cut.
Its under no load when this happens.
Thanks again.
Mike "grimracer" Z
RC stuff..coool me to...
www.grimracer.com
Old 02-26-2004, 01:00 PM
WOODKNACK's Avatar
ok that sounds like you have it set to move to fast. your G00.
turn down your rapid speed and try it.
I have mine turned down just to make sure there is not a problem. plus what I am cutting (aluminum) i cut at 6 IPM and rapid at 15 or 20 ipm.
Old 02-26-2004, 01:04 PM
Grimracer's Avatar
Wood
Thanks and i will try again.. I have cut at 10 IPM and had the same problem but i will re-check my set up and try again
Thanks a bunch
ROCK ON
grimracer
Old 02-26-2004, 01:08 PM
WOODKNACK's Avatar
your cutting at 10ipm (G01) should be fine.
sound like your rapid move (G00) that is giving you the problem.
Old 02-26-2004, 01:17 PM
Grimracer's Avatar
Wood
Yes yes yes...I might know what that is..
G0=Rapid Travel
G1=Lineat Interpolation
Hea..this is G code..."can you tell that im new to this"
ROCK on
Now for the BIG question....How do I change it.... Im not Kiddind...im as new to this as a 16 year old school girl in the back seat of the ol mans ford at the drive in..
Cheers
Grimracer
Old 02-26-2004, 01:52 PM
WOODKNACK's Avatar
im not sure in your software setup. I use turbocnc for mine..
Old 02-26-2004, 01:55 PM
Grimracer's Avatar
Wood
If you go to http://www.microproto.com/ you will learn all the stuff about my machine.
half the stuff is greek to me...But Im Learning thanks to you...
ROCK ON
Grimracer
Old 02-27-2004, 04:15 PM
Grimracer's Avatar
GOT IT
http://www.grimracer.com/Grims%20CNC%20page.htm
Check out the link to see the mill in action
Thanks a ton Wood..
Wood is Good...Hehehe
ROCK ON
Grimracer
  #11   Ban this user!
Old 02-27-2004, 04:50 PM
buscht's Avatar
buscht is on a distinguished road
Pretty impressive for your first effort!
T
  #12   Ban this user!
Old 02-27-2004, 06:47 PM
teilhardo is on a distinguished road
I'd say. That is an excellent first attempt.
As to your minor glitch... As Woodnack says, it probably is your rapid command. I checked out Microproto but they don't have any instructions posted online to use MPS2000. I'd guess that there is a settings or control panel box where you can manually adjust all of the step rates. The computer sends pulses (in hz.) to the stepper motor, if you slow down the rate of the pulses (the setting should say somthing similiar to: "stepping rate" or "frequency" ) then the motors should stop stalling. Just a guess though
Good Luck
Tei
-Please check out my webiste-
http://www.teilhardo.com
Anyone bought a Taig CNC from A.Rotondi Engineering? juaumu Taig Mills & Lathes 2 06-28-2006 01:40 AM
Taig or Minitech Desktop cnc mill qsacracer Taig Mills & Lathes 8 12-01-2004 04:11 PM
Total Newbie on Taig CNC Mill!! vwgo Taig Mills & Lathes 2 10-17-2004 08:40 PM
Taig CNC ready setup help?? efreak Taig Mills & Lathes 2 08-24-2004 08:30 PM
Taig lathe Threading and CNC questions anoel Mini Lathe 5 01-12-2004 04:43 PM
