Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 01-13-2004, 02:03 AM
stokessd's Avatar
stokessd is on a distinguished road
My custom stepper box for my Taig mill
I designed and built my own stepper drivers based around the Allegro 3977 chip (the same as zylotex uses). I also have a limit and relay board for spindle and coolants etc. I used the mill to build the box and engrave it. Pictures are here:
http://www.quadesl.com/albums/stepper.html
My completed mill and lathe are here:
http://www.quadesl.com/albums/taig/taig_done.html
I made them portable because my bench is also an electronics bench, woodworking bench and photographic darkroom.
Sheldon
Old 01-13-2004, 02:19 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
That is one sweet shop set-up you have there! Wow I love your controller box, nice and clean!
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-13-2004, 02:51 AM
pack rat is on a distinguished road
very professional job. Tidy and neat wiring too.
Old 01-13-2004, 02:04 PM
anoel's Avatar
anoel is on a distinguished road
Nice.
How was the "cost : Benefit" of building your own drive boards? The Xylotex are priced reasonable, was it worth it to build your own? I ask cause I'm considering cobbling together a chopper board of my own, just haven't decided on the chipset.
Those Sescom boxes are very nice Pricey but nice. That's what I used for my Gecko box. (That I'm selling )
Nathan
Old 01-13-2004, 04:55 PM
pminmo's Avatar
pminmo is on a distinguished road
stokessd, shop is way to clean! I too have done a board on the allegro chip, a coworker has done the limit board. Currently off to olimex for board fab. Any gotcha's on the 3397?
Phil
WOODKNACK's Avatar
WOODKNACK is on a distinguished road
NICE,
Looks alot like mine. I need to get out in my shop! Just too cold right now. Going to be -30 tonight!! with wind chill around -60.
My little piece of the web!
http://users.adelphia.net/~wjdupont
Old 01-13-2004, 05:16 PM
pminmo's Avatar
anoel, the reason I didn't go with the Xylotex or thk was the lack of input conditioning on the step and dir lines.
Old 01-13-2004, 06:55 PM
stokessd's Avatar
Well, the allegro chips were free samples, so I built my 3 axis board for about $30 or so in parts. I also use the case side for a heat sink and don't need a fan. I also use a 7805 regulator for the logic level voltage without some sort of "power steal" kludge. The boards offer 8 amp switching of spindle and coolants as well as inputs for limits and home switches. The real benefit was that it was cheap, an fun to build my own driver. That's part of this hobby right? Building things...
Yes, that's the biggest problem with those chips. I have 10K resistors in series on the input lines and a 47 pF cap to ground. that does a nice job of filtering the grunge out.
stokessd, shop is way to clean! ... Any gotcha's on the 3397?
YES, I like a clean workspace. The floor is painted with two part epoxy paint and my cars are spotless behind the photos (highly polished too). the biggest gotcha is the input are very noise sensitive, and are millimeters from a huge noise source (the outputs). Input filtering is a must, I also used inverters to buffer the parallel cable lines on the board before the filters. IF you aren't careful the steppers will wander around from spurious input. The filters described above solved my problems.
That allegro chip is way too fast and as a result is sensitive to the same RFI it generates. What stepper needs 500KHz pulses?!
Sheldon
Old 01-13-2004, 09:00 PM
pminmo's Avatar
Yes my board has 40106 cmos schmitt trigger inverters. I figure with the hysterisis inputs combined with the slowness of the cmos, plus a lower impedence pull up on the input. There is a spot for a cap just in case.
Old 01-14-2004, 01:16 AM
stokessd's Avatar
I thought something similar, that's why I put the inverters in my design and that wasn't enough. I ended up putting those RC filters right next to the chips.
Make sure you have provisions for them, my exerience says you'll need them.
Sheldon
  #11   Ban this user!
Old 03-23-2004, 02:17 PM
kfong is on a distinguished road
We designed one as well, went with the lmd18245 chip set.
3amp 55volt microstepping chopper driver board, all parts can be found at Digikey. Works great and the software is open source. At 8 microsteps, it seems like a servo motor. Very smooth and fast. All info and schematics are posted on our web site. National gives out samples as well.
http://www.embeddedtronics.com/microstep.html
Kin Fong
Robotics, CNC, and Controllers
Taig Mill, US Digital MS23, Controller??? marjamar Taig Mills & Lathes 3 02-07-2007 10:16 AM
Taig mill accuracy dberndt Taig Mills & Lathes 14 12-28-2004 10:36 PM
Total Newbie on Taig CNC Mill!! vwgo Taig Mills & Lathes 2 10-17-2004 08:40 PM
MicroProto Taig Mill vayacon Taig Mills & Lathes 4 10-14-2004 04:58 PM
Master5 Taig Mill Setup Jcadwell Mach Mill 2 11-08-2003 06:53 PM
