| Taig Mills & Lathes Discuss Taig machine here. |
| Using Home and Limit Switches on a Taig Hey Guys, I will probably get my Taig mill within 3 months, and I was looking into these: http://www.hightechsystemsllc.com/in...s/Page1220.htm I understand what the limit switches do, what do the Home switches do? Also, I am using the Xylotex 4-axis control board. How would I go about hooking these up to the board...Can I? Thanks a bunch guys, I appreciate it. Burn |
| Home switches tell the CNC controller where machine Zero is for the X, Y, and Z. I got the ones from Hightech, and they mount pretty easy. I used this diagram from Xylotex to hook them up. The one for the Y Axis has to be hooked up opposite to the X and Z, because the switch is always clicked until it is home.
__________________ GlenBA www.lathedweller.com |
| Thanks ![]() Okay, so if I wanted to do limit switches, are they hooked up in the same place, just configured differently in Mach3? |
The other 3 limit switches are usually hooked in series and closed when not tripped, that avoids having to have to use 3 inputs. Instead you use 1 pin, and any of the switches that break the circuit will cause Mach3 to register a limit. Also, remember to always hook up limit switches so that when the trip it is an open circuit, that way if a wire breaks you will know it when it breaks, instead of when the switch trips and does not register in Mach3.
Thanks again. |
| Okay, so would I need 2 sets of limit switches for both ends of travel? All the way left and all the way right, in the case of the X axis, and all the way in and out for the y, and up and down for the Z? |
Home switches are very useful if your going to be using offsets like G54, G55, G56 and so on for job setups. Every time you start your machine you can zero it out using the home switches, then all your offsets are set up because you set their values from machine zero or home position. The limit switches are a little less useful as you can set up soft limits in Mach3, so the machine will stop if your code says to move beyond the machine envelope. Of course, this won't help if the the steppers go berserk.
| Well, it looks like I may be going servo from IMservice. Thanks for the pointer on the Z limit. |
#10
| Im in the process of hooking up 3 home switches on my Taig. Durring normal operation is the curcuit closed having the voltage/reistance though the wiring and when it gets to the home position the switch opens so there is no circuit? Or is The other way around where The circuit is open durring normal operation, and when it gets to the home positions the switch make the circuit closed/powered? VCC and GND terminals on the Xylotex board with the 10k ohm resitors? I have the newer 4 axis board with P pins labeled. Im going to be using the X home, and Y home, Z home, selections in mach3. Do i activate the Active low buttons too? This is confusing. I need a a total made diagram. lol |
#11
According to the "Ports and Pins" configuration screen for "Input Signals", 10-13 and 15 are inputs. I believe it's active high, but you'll be able to see in the Diagnostics window for Mach when the switch is active.
#12
| wow, thanks for clearing those things up for me. I only see active lows in the mach3 inputs. ![]() When i have the active lows checked, the diagnostics screen shows everything normal. But when they are unchecked the diagnostic screen shows 3 of the homes lit up. I dont have anything hooked up yet though. I'm sure ill figure it out when i get it all wired up. I already have the swtiches mounted so they click when they dial goes to 0. |
