The TAIG mills and a more torque efficient coupler | | I think something like this made out of aluminum 6061 would make a really good flexible coupler what do you think? My thinking on why they could use a good replacement is this...
Nylon tubes do a terrific job at low speed allowing for slight misalignments as they require only a small amount of torque to do their job but at 600 rpm thats still a "small amount times 600" which can be HUGE especially considering that the available torque from a stepper is falling off fast. Even a tiny improvement in efficiency would have a good effect on the top speed.
FYI on eBay the 1-1/8 round stock you can buy is 24" long and $14.50 or 48" long and $21.50. The couplers as designed are 1.5" long and by allowing 1/4" extra stock for finishing (less if you have a good saw) you would get enough couplers for 4 TAIGs from 24 inches.
This may be my first project for the TAIG as it kills me knowing the TAIG can move the spindle assembly UP at 46+ inches per minute with ease but only if I am holding the motor in place. As soon as I tighten the screws to hold the stepper in place it doesn't even come close to a speed of 46.
High resistance to torsion and Low resistance to slight misalignment would be the result from this?
